Miles on engine, 91,000
Miles on oil, 11,000
OEM air filter
Amsoil EAO-20 oil filter
Oil Consumption, 0.5 qts
2.0L turbo motor
Physical/Chemical Properties:
viscosity @ 100C, 11.46 Cst
Oxidation, 36 abs/cm
Nitration, 36 abs/cm
TBN, ASTM D4739, 4.4
Wear Metals:
Fe, 3 ppm
Cr, 0 ppm
Pb, 10 ppm
Cu, 1 ppm
Sn, 0 ppm
Al, 2 ppm
Ni, 0 ppm
Silicon, 13 ppm (Note: baseline formula contains approx 4 ppm of polymeric silicone as an antifoam additive)
Oil Additives: (API/SL formulation)
Boron, 22 ppm
Mg, 227 ppm
Ca, 3041 ppm
P, 833 ppm
Zn, 967 ppm
Personal Comments: The Pb looks a tad high here in comparison to the trace levels of other wear metals. This could be due to the regular use of fuel additives (Amsoil PI), or the infamous particle streak through the bearings. Engine has used Amsoil with 10k OCI's since purchased and runs like new.
OEM air filter
2.0L turbo motor
Wear Metals:
Fe, 3 ppm
Cr, 0 ppm
Pb, 10 ppm
Cu, 1 ppm
Sn, 0 ppm
Al, 2 ppm
Ni, 0 ppm
Boron, 22 ppm
Mg, 227 ppm
Ca, 3041 ppm
P, 833 ppm
Zn, 967 ppm
