Hey all. I finally Finished out my full year interval for the Amsoil S2000 0W30 I started with on April 30, 2003. The total kms was 27,164 (approx 16,879mi) and the engine had 109,366kms(68000mi) when it was first added to the engine. Did the 6-month change on Oct 30th with a top up litre of oil at that time. I needed to top it up a little too as the car seems to use some. I may cut the filter open later too. The lab is Metro-tech systems in Calgary Alberta.
This car has been run on a K&N air filter for most of it's life but I changed it out for a Wix about 3700kms (2300mi) ago.
Also, I couldn't really afford the acids/bases test right now and that's why they're not present.
My Sample/New stuff
Tin: 6/0
Lead: 21/0
Copper: 4/0
Aluminum: 4/.9
Silicon: 21/2
Iron: 32/3
Chromium: 3/.2
Silver: 0/0
Zinc: 1200/1700
Magnesium: 878/334
Nickel: 1/0
Barium: 0/0
Sodium: 9/3
Calcium: 2000+/3000
Vanadium: 0/0
Phosphorus: 1050/1400
Molybdenum: 10/0
Boron: 31/2
Manganese: 264/1
Viscosity (D445) @100C - 13.77 (new is 10.89)
Water = 0
Solids = 0.1 new = 0
no Fuel Dilution or Glycol
Lab Comments;
"Tests indicate the need to CHANGE OIL & FILTER. Dust/Dirt (B). Cylinders; pistons; rings wear (A). Main or rod bearing wear (B). Maintain routine sampling.
Rating system; A) low
B) low to moderate
C) moderate
D) High
E) severe
I've tried to show exactly what's on this report with some formatting.
What do you folks think?
Greg
[ May 05, 2004, 08:12 PM: Message edited by: Horatio ]
My Sample/New stuff
Tin: 6/0
Lead: 21/0
Copper: 4/0
Aluminum: 4/.9
Silicon: 21/2
Iron: 32/3
Chromium: 3/.2
Silver: 0/0
Zinc: 1200/1700
Magnesium: 878/334
Nickel: 1/0
Barium: 0/0
Sodium: 9/3
Calcium: 2000+/3000
Vanadium: 0/0
Molybdenum: 10/0
Boron: 31/2
Manganese: 264/1
Water = 0
Lab Comments;
B) low to moderate
C) moderate
D) High
E) severe
Greg
