Amsoil is a great oil, one of the best. I've had some really good UOAs...BUT, a lot of engines won't go 25K on it, especially without UOAs to back it up. If you are running an EaO oil filter, and a good air filter, and doing UOAs, and have an engine that is easy on oil, then you may hit 25K or even more. Otherwise, you probably won't safety hit 25K. If money were no object I would run Amsoil in most or all of my vehicles. Right now with the sales and rebates on several of the group III "synthetics" I have been buying a lot of good oil for $1-4 a quart (yes, $1 or less, with the occasional Pep Boys/Quaker State rebates). Running 7K-10K OCIs for cheap seems to work pretty well at about half the price, or less, of Amsoil.
If you want one of the "best" oils, and plan on keeping a vehicle past 200K, and want to do extended OCIs, Amsoil should be on the short list.
P.S. Just for disclosure, I am an Amsoil dealer but I'm not trying to sell anyone anything and I don't endlessly push the stuff (as you can see by my post). When Quaker State has a $3 a quart rebate or Mobil 1 is under $4/qt, I buy 'em up. I also use Redline in one of my vehicles and VP racing in another 2 vehicles. Just about any oil will allow a vehicle to hit 200K or more, the trick is matching the OCI to the capability of the oil. Amsoil will allow one of the highest OCIs while still allowing the engine to live a long life, but this can't be done blindly, UOAs are needed at least until the proper OCI is determined.
