Amsoil 5w30 SS - 5,800 mi - 22 Colorado 3.6L
NJ
I sent this sample off last Monday and just got the results today.
Sample 1 - Mobil 1 EP 5w30 Triple Action
Sample 2 - Amsoil SS 5w30
I put 4k of the 5,800 miles on within a week driving out to South Dakota. Rest is probably 50/50 city/hwy. I'm happy with these results.
I requested TAN. Not sure why they didn't include it. Probably why they said to contact them. Oxidation is perfect so I ignore that.
Appears to be "broken in" & wear metals have come down quite a bit from the previous sample. Silicon is showing very low on both which is excellent results. Fuel not out of touch & viscosity seems to be just fine at that level. If fuel stays reasonable like this result that makes a 7.5-10k mile ODI easy. This SS is long drain oil as you well know.
Then their tin flag is moot on your UOA. Viscosity well in grade still. I think 7500 miles could be the sweet spot for that oil without going too far with it (room to spare). How are you liking the Colorado? I know you trade up but still plan on keeping it for a bit longer?
Good point. (y) I'll be curious how it does over winter and how it holds up to more short trip/cold weather. Should be interesting to compare.
I enjoy the truck a lot. Not too big or small. V6 is nice and transmission is smooth. There are some minor issues I've had - paint chipping on driver's side door handle, key will get stuck in ignition now and then. Other than that it's been solid. I think GM did a great job with the new one. I plan on keeping it at least another year, maybe longer. I'm going to play it by ear at this point.
The virgin KV100 of the M1 EP/TA 5w30 is 10.45 cSt. Factoring out the 1.7% fuel dilution, the KV100 of the oil alone is 9.89 cSt meaning the M1 EP/TA 5w30 sheared -0.56 cSt. (-5.36%) That's actually decent for an API oil with a 35 SSI OCP.
The Amsoil SS 5w30 has a virgin KV100 of 10.3 cSt. Factoring out the 1.9% fuel dilution, you get 10.28 cSt meaning that oil didn't shear at all.
Neither oils were run long enough to see any substantial increases in viscosity from oxidative thickening, soot loading, etc... thus, I'm not factoring that in. This also assumes the KV100 is exactly 9.400, 9.700, etc... which it likely isn't.
I see no reason you couldn't go 10k miles on the SS 5w30.
From the Acadia forum - GM 3.6L and Amsoil SS 5w30. Just used in a very different way (not my report). 10 mile round trips and some highway. Fuel dilution in GDI engines for ya.
At 4.6% fuel dilution, the viscosity became 8.8 cSt.
Held up very well, given relatively short trips and less opportunity to burn off excess fuel.
