Miles on Civic- 524,636
Miles on oil - 14,198
Amsoil 0W-30 AZO
Amsoil EAo36 oil filter
Twin Filtermag CT3.2 magnetic oil filters
Dimple magnetic oil drain plug
5 ozs Liquimoly
47 ozs make up oil
Blackstone Labs; We're still tracking the possibility of a coolant leak for your Civic, and the increase in Potassium suggests it's
getting worse. Sodium hasn't increased much, but you'll want to keep and eye out on your end in case the coolant
level is getting low on you. Copper increased enough to mark too, but 6 ppm isn't really a lot of brass/bronze wear in the
grand scheme of things, so that's just to watch now too. The TBN came back OK at 2.6, and the PCread
17/16/14. WEsuggest cutting back to 10kK miles again because of the
Code
[/code]
Aluminum----------------4-------------------------------------------------4 universal average based on a 3,600 mile OCI
Chromium----------------1-------------------------------------------------1
Iron-------------------------20------------------------------------------------9
Copper--------------------6--------------------------------------------------3
Lead------------------------3-------------------------------------------------2
Tin--------------------------0--------------------------------------------------1
Molybdenum-------------325-----------------------------------------------85
Nickel-----------------------0--------------------------------------------------0
Manganese----------------0--------------------------------------------------0
Silver------------------------0--------------------------------------------------0
Titanium--------------------0--------------------------------------------------1
Potassium-----------------90-------------------------------------------------4
Boron------------------------40------------------------------------------------50
Silicon------------------------19-----------------------------------------------11
Sodium-----------------------22-----------------------------------------------43
Calcium----------------------1248---------------------------------------------2135
Magnesium------------------750-----------------------------------------------151
Phosphorus-----------------784-----------------------------------------------713
Zinc----------------------------823-----------------------------------------------833
Barium------------------------0---------------------------------------------------0
Amsoil 0W-30 AZO
5 ozs Liquimoly
47 ozs make up oil
Code
[/code]
Code:
SUS Viscosity @ 210 F--------------------------66.7---------------------------------------------------57-67 (value should be)
cSt Viscosity @ 100 C----------------------------12.06--------------------------------------------------9.4-12.4
Flashpoint in F---------------------------------------390---------------------------------------------------->385
Fuel%--------------------------------------------------- Antifreeze %--------------------------------------------POS-------------------------------------------------0.0
Water %--------------------------------------------------0.0--------------------------------------------------- Insolubles %--------------------------------------------0.3---------------------------------------------------- TBN-------------------------------------------------------2.6---------------------------------------------------->1.0
Particle counts for ISO oil cleanliness code 17/16/14;
>= 2 microns---1,818 particles
>= 5---------------673
>= 10-------------186
>= 15-------------72
>=25--------------17
>=50--------------1
>=100------------0
