Anybody here shooting air rifles?
Any thoughts on the ideal all-around pellets for .177 and .22?
Are we talking air rifles or pellet guns?Anybody here shooting air rifles?
Pick a pellet that stays subsonic,
How many air rifles are able to shoot above 1100 fps?
Is the OP asking about buying a rifle or getting ammo for his .177 & .22 rifles?
I do.
It's unfortunately dependant on the rifle. And on what you're shooting at. I like Crosman Premier domed pellets, but also have a lot of JSB, and some H&N.
The crosman are a bit harder than jsb, so penetrate deeper.
Pick a pellet that stays subsonic, with good ballistics as a candidate for testing.
...I need to shoot my air guns more.
I could set you straight in short order . I prefer to call you one night as that would be the quickest and easiest way to get you on track.If I had to say what was the best thing I ever did to reveal and get rid of bad shooting habits it was shooting the .177 Beeman. The lock time and the barrel time are so incredibly slow, if breathing, posture, follow-through, muscle tension, grip, balance, really everything, are not good, the shot will not be accurate.
Air rifles are so satisfying and inexpensive to shoot I wonder the same thing every time I bring it out -- "Why don't I do this more often?"
The break-barrel Gamo definitely takes some effort, but I eventually figured out if the butt is on the ground just so, then there's an angle you can get on the barrel even sitting in a chair that isn't bad.
Perhaps with the help of folks here, I need to find one pellet to settle upon. The variability between different weights and brands of pellets is not acceptable for what I'm trying to do. I want to sight this Gamo in one more time and leave it there. I will never be shooting long distance, and if it takes out a squirrel in a relatively humane manner then that will be the one I use for target practice as well.
