Air filter that works well and allows good air flow
FL
Looking to replace a
BMW 325i
Jeep patriot
Chevy tahoe filter
Hows the fram air filter ?
What about mahle air filterfor BMW
I have a wix in tahoe now with about 30k
Factor jeep filter in patriot with 38k
No idea what Brand in BMW or milage.
Any other suggestions under 15 each ?
They might be ai bit more than you want to spend, but Fram makes an Ultra air filter that's only sold by Walmart.
I emailed Fram about the efficiency, and this is what they said. Note that Fram uses the fine dust in the ISO 5011 efficiency test. Some filter makers use the course dust to boost efficiency numbers.
https://www.bobistheoilguy.com/foru...r-options-for-4-0l-v6-toyota#Post5157345
Also, they said the new filter pressure drop was only 1.5 in-H2O at 250 CFM air flow for my particular filter model, which is ptetty free flowing.
Originally Posted by LotI
OEM's designed the stock air filter to flow as much as needed.
Mann, Mahle, or Wix should be the best you can find for all of them.
+1
Originally Posted by GMguy84
Originally Posted by tblt44
Supertech ?
As far I have seen, Supertech doesn't make air filters
Dave
They do. Ive seen them at a few Wal Marts in New York. Apparently they're made by champion
Supertech air filters are only a few bucks less than fram at walmart.
Which is better?
Which is better?
Don't realky know unless you can get ISO 5011 efficiency ratings. And you have to ensure you know if the ISO test was ran with the test specifief fine dust or coarse dust. Air filter efficiency testing is more convoluted than oil filter efficiency testing.
Ended up getting the fram ultra air filter from walmart.
For 3.50 more than the regular one.
The Ultra air filter is rated to last twice as long (has greater holding capacity) as the regular Fram filters, so it's actually cheaper if based on how long you can run it for the cost.
It was 16.97 vrS 12 50 looked like it would filter better.
Built well also with glue that holds pleats apart
Must members will not use the filter anywhere near capacity.
Supertech is rated for 30k
I have one on order for daughters car to check it out.
Looks like they seal better with the rubber gasket. The Ultra has it unlike the new regular one. The old regular Fram used to have the rubber gasket but not any longer.
The store here doesn't carry them but I can always order it online. But not sure which model number I need. 2005 Toyota Matrix 1.8 if anyone knows. Thanks.
Go to walmart.com search supertech air filter,
Pick any one to add to cart, than it will ask for your car info.
Than you can choose filters to fit that car
