I never had much luck with them. Depends on the application though and cable length. Disclaimer, I use the parking brake all the time...
Had many warrantied thru NAPA.
Some were made in the US, Canada, China.
I had some that the eyelet broke off, others seized up(either corrosion or mechanical), others that lacked segments of cable protection like the OEM and wore thru, and others (the latest one) don't have a good fit.
The Wagner one I got won't go all the way on the actuator hook, will sit at a 45 deg angle, it could probably be widened out a bit with a file. It is spring loaded, so it may come off. Looks like a quality cable though otherwise, made in Canada.
Dealer ones are expensive and for my cars not really available.
