Advances in auto countdown and humidity triggered fan switches.
SE British Columbia, Canada
I came across some better products from Lutron.
They always had a countdown timer where you select the amount of time you want the fan to run. It used to be a fairly deep housing taking up 1-1/2 inches of space. If the electrician used the box as a junction box, sometimes there wouldn’t be space for the count down switch. The new switch is a 1/2 inch shallower so for some, there is now space to install one.
They also have a programable switch that will come on automatically come on when a certain humidity is reached and shut off when the humidity goes back down. My old one was a Broan and required a big box extending a few inches from the wall. The Lutron version is almost flush with the wall and can be programmed to do timed circulation required by some building codes out there. Here are a few shots. Enjoy. Old and new for the countdown switch, then old and new for the humidity switch. Sorry the the sideways views.
im not a fan of the humidistat style. i have a timer in my bathroom set for an hour run time all you got to do is push the on button it will recall the last selected run time. just like this one.
I've got a few years old humidity sensor in my bathroom and it's all but worthless for that. It does also have a manual override with timer that I generally use.
Have an issue with everyone else in the house steaming up the bathroom, hoped it would address the issue, did not.
Had to replace mine.. Hurry job..
only thing HD and lowes had .. has goofy settings
5min 10min 30min 60min 2 hour 4 hour.
10min not long enough.. 30min too long.
