ABS light
NY
Hi:
The car is Acura Integra '97 (140K miles). I noticed the ABS light is lighting up when it is cold. When the car warms up, the light is off. What seems to be the problem? Thanks for the help.
George
I'm sure it isn't a problem, since it is going off when warmed up brake lines get slow in cold, if you are noticing braking probs take it to a shop, if you are worried take it to a shop. Personally I would want to have a competent mechanic take a look when such an important component of my vehicle is acting up. I'm sure it has been cold before. How long has it been since you have serviced your brakes??
Thanks for the reply. I did not notice any problems with the brakes. Perhaps I will look at the accumulator to see if there is a problem.
George
