I have a 98 Mustang GT with 96,950 miles. It is automatic. I maintain the car meticulously. Oil used is QS Advanced 5w30....just completed an auto-rx treatment. Transmission fluid was changed a month ago.I've had a problem with my BBK Under drive pulleys causing my serpentine belt to "glaze". The belt is making a little noise. The UDP's are piggy back style.....they use the existing harmonic dampener....I dont think this could be causing the harshness but i have replacement pulleys on the way because I want a one piece design. When i first start up the car it idles rough...It never did this before...If i look under the car i hear tapping coming from the bottom of the engine and i can literally see the H-pipe rattling around (it is not loose). After about 20 seconds the tapping stops and the engine runs rough. I replaced the plugs last month and the wires about a year ago. PCV valve is also about a year old. Air filter brand new amsoil eaa..02 sensors brand new.....just cleaned throttle body and there are no vacuum leaks. Its driving me nuts. Can the pulleys or a slipping belt cause this? I think it is the wires but i dont want to spend 100 bucks for no reason. I also cleaned the idle air control motor but it is still doing it.
