Removing and replacing heater core on a 92 Oldsmobile Cutlass Supreme S, 3.1 engine, LHO VIN T.
Down below in bold, and underlined is what I don't completely understand from the repair manual.
"Disconnect the negative battery cable.
Properly drain the engine coolant into a suitable container.
Remove the upper weatherstrip from the body.
Remove the upper secondary cowl.
Remove the lower secondary cowl upper nut.
Disconnect the heater hoses from the heater core."
