Originally Posted By: zeng
Originally Posted By: Fasttimez
Hey guys, is it me or is 75w-140 rear diff fluid overkill for an everyday driver F150 that doesn't tow anything ?
Gear oil viscosity selection is heavily influenced and determined by linear speed at gear tooth (of differential in this case) .
No towing plus high road speed, lower viscosity gear oil is preferred.
At low road speed,higher viscosity gear oil is preferred.
The rear is not a limited slip, so no clutch packs. It does have the electronic locker. I'm going to be changing out my diff fluid & was going to put 75w-90 full synthetic back in it. I was planning on using something readily available off the shelf such as Valvoline SynPower, which has some great reviews & carries a lot of certifications. Is there any disadvantage to using a synthetic 75w-90 vs 75w-140 ?
At gear tooth linear speed of say, 750 fpm and below, I would abandon xxW-90 gear oil viscosity.
In a differential, generally xxW-140 offers far superior wear protection than a xxW-90.
I tend to believe xxW-90's frictional heat reduction is of no significance.
Like I said, I never tow hardly at all, I don't beat on my truck such as racing down the road or anything. I know my manual specs for 75w-140, but it just seems like overkill for my application.
I see no reason why you are not selecting xxW-140 as recommended. Having said this, I would select xxW-90 if gear tooth linear speed consistently exceeds say , 1000 fpm.
JMO.
So my differential gearing is 3.73:1, I generally travel at speeds of 45mph-70mph. My transmission ratios are as follows 4.17:1(1st gear) 2.34:1(2nd gear) 1.52:1(3rd gear) 1.14:1(4th gear) 0.86:1(5th gear) 0.69:1(6th gear) with 90% of driving spent in 6th gear. Given this information what would be my gear tooth linear speed (aproximate) ? Does it warrant more of a 75w-140 or a 75w-90 ? I'm always curious about things like this.
