https://www.thetruthaboutcars.com/2...nge-procedure-contains-a-big-extra-step/
3 extra steps actually:
1) Remove the Left Front Wheel.
2) Remove access panel in fender liner ( 9 push pins)
3) Remove Shield from power steering controller(4 bolts) to access drain plug.
"Because the 2.3-liter Ecoboost four-cylinder found in the 2019 Ranger isn't exactly the same beast as that found in other Ford vehicles, the oil filter migrates to a slightly new location. A larger oil cooler means the filter no longer hangs towards the oil pan near the rear of the engine. Instead, the filter sticks out the left side, at right angles to the engine's cylinders, making it less accessible for fumbling hands."
