Hi, guys. Thought I'd post another analysis. This is the longest (not terribly long... I know) I've gone so far on an oil change in this car since I bought the car. Wear trends remain stable. Boring report. I'm happy!
Go 10k on a semi ? To save 15 bucks .You can easily extend the OCIs out; double to 10k miles. Plenty of proof that distance is perfect sound. And, as an added benefit, the wear rate will probably go down! Save money and reduce wear; what's not to like about that?
Good info, thanks!IMO, the 4.6 and 5.4 SOHC engines need somewhat frequent oil changes to keep the timing chain guides happy. 4,000 miles is about the longest I go on my 1997 F250 5.4 SOHC engine, now entering 270,000 miles without a teardown and still no oil usage between changes.
Yep, keep giving them the 20K intervals and see how long they last.There is no reliable data that shows any correlation between OCI and timing guide wear. And without correlation, there can be no causation. Generally the chain guides in these engines get destroyed because the guide tensioners start to leak at the gaskets; that had ZERO to do with the OCI duration, and more a result of simple heat cycling and luck. Hence, that's a farcical myth.
The old 2v mod-motors are generally very long lived and are not sensitive to oil brand/grand/OCIs.
Folks who do 3k mile OCIs said that about people who do 5k mile intervals.Yep, keep giving them the 20K intervals and see how long they last.
I really enjoy your posts on the TCB theory relating to OCI's and of course one of it's by products, ROI. Cheers.Folks who do 3k mile OCIs said that about people who do 5k mile intervals.
Folks who do 5k mile OCIs said that about people who do 7.5k mile intervals.
Folks who do 7.5k mile OCIs said that about people who do 10k mile intervals.
See a pattern here?
I've done 15k mile intervals upon occasion in several vehicles over the years. I've pulled valve covers off and looked for sludge. I've pulled UOAs and looked at soot and insoluble counts. Even the Ford/Conoco SAE study I referenced ran the OCIs up to 15k miles for the tests.
As I said before, there is no (zero, none, zilch, nada) correlation in data that shows timing chain guides will wear out sooner with longer OCIs in this engine series. The guide failures are typically because they start to run loose and allow the chain to slap against the guide liner, thereby eventually beating it to death. If you are diligent, you very well may catch it by listening for that slap, and also see it in the UOAs with Al and Fe spikes. But all that has ABSOLUTELY NOTHING to do with the OCI duration.
I would admit there is a practical limit to any OCI. At some point, the additives will be overwhelmed. The continamination will become too great. The vis too thick from oxidation. I do agree there are detrimental effects from over-runing an OCI. It's just that your view seems limited by mythology and rhetoric, not facts based on data.
Since you seem adamant about your position, then please show me the evidence (credible facts like SAE study, or similar) that directly attributes timing chain guide lifecycle to the OCIs. I'm all ears. But please, make sure it's creditbly sourced, and not some YT vid or shade-tree ol' timer who has nothing but suspiciion and wife's tales.
