2007 Camry
Detroit, Michigan
Long time lurker. The woman drives a Mazda 3 that specs 5w-20 and I have used Motorcraft since new. Yota specs 5w-20 in the new ride and it would be easy to use the same oil. Thoughts?
Good choice. For extended drains, I'd use M1 5w-20 or Redline 5w-20.
yep, depends on what your drain interval is...
I thught that toyota was using 0w-20 synthetic oil... or is that only for the fuel economy tests???
0w-20 or 5w20 M1 would be good... depends on how long you plan to keep the car, what your maintenance practices are, etc.
Havoline isanother good oil if youre looking for conventional.
JMH
I have a 2006 4 cyl p/u that per a T.S.B can run 05w20 oil the truvh has had 2 oil changes and has gotten via a scan gauge 23.4 mile per gallon running from Redding ca. to Vacaville Calif.on I5 and 505 with 10w30 5w30 and 5w20 what is the deal ? Thought xw/20 was the cats meow .
FWIW, I have been using Valvoline DuraBlend on my 2001 Camry(Solara) until this summer, when I switched to M1 Full synthetic, now that the engine has 70k on it.
Runs smoother & quieted up when I added some VSOT to it.
Highly recommend the 5w30 M1, if you can get it on sale (actualy $4.79 at Kmart right now...)
GL
quote:
Originally posted by Mr60hertz:
So Moto 5w-20 at 5k?
Sounds like a plan to me. Once you're out of warranty, increase the OCI if you really want to run the oil longer, perhaps with a "full" synthetic instead of the MotorCraft Semi-Synthetic.
