1999 Camry with 2.2L and 108k on it. First UOA. This change had 70% 5w30 and 30% 10W30 QS Advanced Engine Full Synthetic with a Wix filter. Also had MoS2 added with oil. Mixed driving. Car leaks a little from rear main and burns a little on cold start ups but runs great. 1 quart of makeup oil throughout usage period.
Thoughts? How much longer could I have gone?
Code:
Metals (ppm)
Iron (Fe) 5
Chromium (Cr)
Lead (Pb)
Copper (Cu) 5
Tin (Sn)
Aluminium (Al) 6
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 6
Potassium (K)
Coolant No
Additives (ppm)
Magnesium (Mg) 26
Calcium (Ca) 2306
Barium (Ba)
Phosphorus (P) 738
Zinc (Zn) 881
Molybdenum (Mo) 262
Boron (B)
Contaminants
Water (%)
Physical Tests
Viscosity (cSt 100C) 11.6
Physical / Chemical
Base Number (mgKOH/g) 4.2
Code:
Metals (ppm)
Iron (Fe) 5
Chromium (Cr)
Lead (Pb)
Copper (Cu) 5
Tin (Sn)
Aluminium (Al) 6
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 6
Potassium (K)
Coolant No
Additives (ppm)
Magnesium (Mg) 26
Calcium (Ca) 2306
Barium (Ba)
Phosphorus (P) 738
Zinc (Zn) 881
Molybdenum (Mo) 262
Boron (B)
Contaminants
Water (%)
Physical Tests
Physical / Chemical
