'13 VFR1200F XADO Synthetic 10W-40, 5K.
Md, USA
It would be nice to see some lower copper from your Honda. This sample shows an increase in brass/bronze wear, even as several of the other metals improved. It's hard to say exactly what made Copper to read a bit higher here. Maybe a bushing or some other valvetrain component.
If this oil sees use in the transmission, it could be from that too. Since the other metals look good let's see how Copper compares after another 5000 mile run. The TBN is fine at 5.1, just check back on the Copper. Silicon is lower this time so the air filtration system is working well.
Xado 10-w40
No Makeup oil
Baldwin B1400 filter
Miles on oil 5k
Miles on Motor 11k
Aluminum 10/14
Chromium 1/1
Iron 30/38
Copper 25/16
Lead 1/2
Tin 2/2
Molybdenum 6/31
Nickel 0/1
Manganese 2/2
Silver 0/0
Titanium 0/0
Potassium 2/7
Boron 128/15
Silicon 10/19
Sodium 5/7
Calcium 2267/1993
Magnesium 7/11
Phosphorous 947/851
Zinc 1081/977
Barium 1/3
Viscosity @210F 61.8/54.9
Viscosity @ 100c. 10.73/8.74
Flashpoint in F 415/390
Fuel % TBN 5.1/4.6
Previous run was Motul 5100 10w50 Syn blend. Didn't shear as bad this time.
Filled with Klotz 15w50, Donaldson Filter- P502067
Previous Analysis.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4083063/'13_Honda_VFR1200_Motul_10w-50#Post4083063
