They have been using it in all Duratec Foci since 2003.
It is impossible to get pictures of the actual filter element, as it is sealed inside a plastic housing. However, those that have attempted to look at it have identified as multi layer foam. It does not look like normal foam however, more like a sponge material. When I looked at my unit, I would of swore I saw some form of oil on the filter, but like I said its impossible to tell.
I am not about to crack it open either as its really expensive and I may need to revert to stock later.
I can tell you that my car gained 10hp at the wheels (dino proven) when I removed the factory intake system. On a 144hp engine that is not bad, not bad at all.
