03 Toyota Tacoma 3.4 Mobil DC 10w-30 this sample with Toyota filter (paper type) First interval factory fill 5w-30 with factory filter.
Blackstone Labs:
Nice improvement in wear and silicon. Both were high last sample due to break-in, and while the silicon is still a little high in this oil, the wear has settled right down to normal levels. We expect silicon will continue to drop in the next sample, and should read at a normal level by the fourth oil change. The viscosity was a little light for a 10W/30, but the flashpoint was good, so we don't suspect you have any fuel problems. No anti-freeze was found. At 7490 total miles, this engine appears to be doing well.
[ November 06, 2003, 10:16 PM: Message edited by: Brent ]
Blackstone Labs:
Blackstone's comments:code:
Miles on unit 7,490 3,838
Oil Toyota 10w-30 5w-30
Miles on oil 3,652 3,838
ALUMINUM 2 6
CHROMIUM 0 0
IRON 6 12
COPPER 12 80
LEAD 1 3
TIN 2 3
MOLYBDENUM 4 42
NICKEL 0 1
MANGANESE 1 2
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 0
BORON 1 0
SILICON 34 173
SODIUM 1 3
CALCIUM 2071 1720
MAGNESIUM 6 5
PHOSPHORUS 871 694
ZINC 991 820
BARIUM 1 2
VIS 58.7 55.4
FLASH 385(F) 355 (F)
FUEL
WATER 0 0
INSOL 0.3 0.3
