03 rav4 2.0 awd only took 2qts of mtf?
Lacombe ab Canada
Dealership and technical data sites show this 03 rav4 awd 2.0 takes 3.5L of mtf. After 2 qts of mt90 it was not dripping out of the fill hile. As i started with a 3rd qt it immediately dripped. Shifts fine. Is it good?
Internet write ups show 2 qts i seen. Some say the transfer case is shared with the transmission but the manual shows to use a different gear lube. Dealer says it is a seperate non connected item and does not share oil. Also gl5 oils to be bad on the syncros so i used red line mt90 and shifts feel fine. Better than what was in it.
There is a oil cooler for the 5spd trans. Maybe that's why it only took 2 qts ? The rest is maybe in the cooler to equal 3.8 qts as per the dealer and the manual?
Fluid was hot. 2.5L at the most came out. It would not take much more than 2 bottles. Car is currenlty being used but im sure it also said 3.5L in the manual. I will have to check that later.
A fill plug won't lie.
Re-check your manual. If it is indeed 3.5L, wait a month or so and do another drain and fill with the transmission cold.
ok.will do. Is it weird that this manual transmission has a large front mount oil cooler? Maybe 1.5L is stuck in it? Cant see how the 90 weight oil would push it self through it. Would it have a pump? Also could it be oem? Or was this a auto befor ha. A YouTube video on a 99 rav4 mtf diy had a oil cooler as well.
Thanks guys.
