gathermewool
Site Donor 2025
Originally Posted by Darwin1138
Originally Posted by eljefino
Those bottom rungs "should" just be stiffeners under light load-- yes the legs will want to "split" away from center but they have solid welds up top with lots of contact. Still, I'm not a jack stand engineer, and can't recommend someone go against their better instincts and potentially compromise their safety.
The force that those stiffeners are resisting is:
F=(W/3)*Tanα*Cos30°
Where W is the weight applied to the jack and α is the angle between the leg and the vertical, which judging by the photo appears to be 30°
For a load of 6000 lbs that force is 1000 lbs Which i don't think is a small enough force to be dismissed like many here are suggesting, and I wouldn't trust that weld from the third photo to hold it.
Now, certainly you could make a jack stand without those components or even remove them just for kicks. In that case the force trying to rip apart the leg from the central support, or the force that the welds from the last photo will be resisting is:
F=(W/3)*Tanα
Which for our load of 6000 lbs is 1155 lbs
Are those welds strong enough to resist that kind of force?
Maybe, but even if the stand could work without problems without the cross members, I don't think they should be treated as "aesthetic enhancers" but as an integral part of the design.
In short, yes, those welds are wrong.
I don't believe you math is all-inclusive.
Those crappy welds are not holding 1000# max. I argue that the vertical welds are withstanding nearly 100% of the load, whereas the crappy welds are only there to stabilize the jack in place.
Also, based on the picture, the legs are square sections, which are incredibly rigid and have a very high bending modulus, meaning they're probably nearly as resistant to bending as the vertical welds themselves. Within the constraints of the load rating, I doubt those vertical welds nor legs will bend enough perceptibly, again meaning that the stabilizers (with crappy welds) won't see any strain due to the load, unless the load is cocked and the jack is wanting to twist.
I'm a nuke, NOT a structural engineer. This is all based on the limited welding and fab work I did out at sea as a NOVICE, as well as stuff I learned in the few structural classes I took in college.
F=(W/3)*Tanα*Cos30°
F=(W/3)*Tanα
