Recent Topics
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
0 seconds ago
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
21 minutes 54 seconds ago
new Tundra color
by lawnman
24 minutes 15 seconds ago
Bought A Yamaha XSR900 today!
by donnyj08
39 minutes 20 seconds ago
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
51 minutes 40 seconds ago
Replace oxygen sensor by mileage ?
by Merkava_4
58 minutes 21 seconds ago
I was slightly wrong on the Purolator transition
by slacktide_bitog
Today at 09:57 PM
Things your dogs have eaten.....
by OVERKILL
Today at 09:45 PM
What Happened To Johnny ??
by crazyoildude
Today at 09:39 PM
Home Depot--Formula Shell--Buy 4 qt. get one free.
by BigD1
Today at 09:34 PM
Varnish in engine
by paulri
Today at 09:23 PM
Lubrication Engineers 75w90
by Hullthumper
Today at 09:19 PM
Newest Members
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
Who's Online
80 registered (01rangerxl, 97K15004WD, 901Memphis, aquariuscsm, 92saturnsl2, 9 invisible), 1464 Guests and 13 Spiders online.
Key: Admin, Global Mod, Mod
Forum Stats
58341 Members
66 Forums
251126 Topics
Max Online: 2862 @ 07/07/14 03:10 PM
Donate to BITOG
Topic Options
#1645328 - 10/25/09 02:14 PM Oil for 2005 Impala w/ 3.8 Series II
04SE Offline
Loc: IL
Ok, this motor for years was spec'ed with 10w30 by GM and ran for a very long time. They are extremely reliable. My 05 impala has a 5w30 oil cap. I have ran 5w30 for 25K and have not had a problem.
Did anything in the L36 change for GM to recommend 5w30 or is this their way of getting more MPG across the fleet like Ford did with 5w20?
I have a stash of Shell 5w30 that I had intended on using up in this car but with Pennzoil Platinum and M1 coming back down in price, I might switch it over to synthetic. Just wondering what grade to run for the next 100K. I am really interested in M1 0w30.
_________________________
#1645341 - 10/25/09 02:34 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: 04SE]
wapacz Offline
Loc: MI
5w is just your cold flow number. Pretty much means you can start the car in colder temperatures and still be fine.
The change probably happened because oils got better. The oils got more shear stable which made making the 5w30 easier. If we ever find a way to make cheap shear stable 0w30s I bet those will be come recommended from oem, but for now they require synthetics and that makes them expensive.
Edited by wapacz (10/25/09 02:39 PM)
#1645355 - 10/25/09 02:45 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: wapacz]
daves87rs Online   content
Loc: Michigan
+1
Whatever you are, be a good one.
#1645418 - 10/25/09 03:55 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: daves87rs]
Petrou Offline
Loc: Bismarck, ND
it will be ok to run 10w-30 but i would stick with 5-30 for cold like it said above. or 0-30. or really that motor likes synthetics as well
1992 TOYOTA PICKUP 4X4 22RE 5SPD
1994 Land Rover Discovery 1
#1645455 - 10/25/09 04:31 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: Petrou]
sciphi Offline
Loc: Upstate NY
I have a 1999-spec 3800 Series II. It runs fine on 5w-30. I have dino in there right now since it was in the stash. It's seen a little bit of 10w-30 and lots of 5w-30 since it sounds better on startup with 5w-30.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#1645536 - 10/25/09 05:29 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: sciphi]
daman Offline
Loc: Bad Axe, MI
ive had two NA 3800's both took 5w30
"Always"....Mobil 1
Current fill: AFE 0w30
#1645547 - 10/25/09 05:35 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: 04SE]
Merkava_4 Offline
Loc: Clovis, CA
I would ignore the 5W-30 oil cap and run 10W-30 Maxlife.
A 10W-30 oil cap is readily available for that engine.
#2698104 - 07/28/12 03:46 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: 04SE]
Ram01 Offline
Loc: New York Queens
10w30 Mobil 1 will be fine
#2698224 - 07/28/12 06:16 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: 04SE]
Nickdfresh Offline
Loc: Buffalo, NY
0W-30 AFE would probably work great. These engines run fine on either 10W-30 or 5W-30 and my old 1990 Buick LeSabre 3800 actually called for 5W-30. I'd use the Formula Shell in the warmer months and try the 0W-30 in winter...
#2698259 - 07/28/12 06:52 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: Ram01]
tsduke Offline
Loc: Iowa
Wonder if the OP has the car anymore. Post was almost 3 years ago.
#2698369 - 07/28/12 08:40 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: 04SE]
Ram01 Offline
That's true but plenty of people on this forum may have the wonderful 3800 series from GM. And want info on which grade to use
#2698463 - 07/28/12 10:22 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: Ram01]
oldmaninsc Offline
Loc: California
That's a good point, but there is also this thing called an "owner's manual." Lot's of good info. in there! smile
2013 Chevrolet Impala LT
2004 Mercury Grand Marquis LS
2005 Toyota Camry LE
1998 Ford F-150 XLT
#2698479 - 07/28/12 10:44 PM Re: Oil for 2005 Impala w/ 3.8 Series II [Re: oldmaninsc]
Garak Offline
Loc: Regina, Saskatchewan, Canada
And there aren't a lot of three year old SM/GF-4 oils left on the shelf, either. What was valid three years ago isn't necessarily current now.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
