Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
Car's models of 1990 and now
by HTSS_TR
05/30/16 07:02 PM
Another dealer oil change story
by mclasser
05/30/16 06:36 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
41 registered (CKN, andrewp1998, chrisri, clinebarger, bdcardinal, Abakev, 9 invisible), 750 Guests and 313 Spiders online.
58031 Members
66 Forums
249616 Topics
#989109 - 09/15/07 02:15 AM Acura 2003 CL-Type S--5 20 or 0 20 for Winter?
Snowflaque Offline
Loc: Minnesota
I have been using Mobil 1 5-20w as recommended for My Acura.
Would AMSOIL 0-20 provide more protection during a Minnesota winter?
thanks
John
#989110 - 09/15/07 02:49 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: Snowflaque]
XS650 Offline
Loc: Northern CA
Yes, the 0W-20 would be better for your climate.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#989111 - 09/15/07 03:21 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: XS650]
98LSC32V Offline
Loc: SF Bay Area
Amsoil ASM 0W-20! Mobil 1 also makes a 0w-20 if you can find it.
1998 Lincoln Mark VIII
4.6 DOHC 32V: Mobil 1 0W-20 Extended Performance, Motorcraft FL820S, K&N Air Filter, Mobil 1 Synthetic ATF, Mobil 1 75w-90
#989112 - 09/15/07 06:01 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: XS650]
06VtecV6 Offline
Loc: Texas urban DESERT 9/12 months
So then by this logic, 0w-20 would *not* be good for hot + humid climate of South Texas? I was going to possibly try it now that my warranty is out and Fall beckons.
PenZ ULTRA 5w-30 4600 miles on a ~8k OCI
This B5/Dexos1 PUP cleans..1 quart used..!
95 SC3 152,8k no VVT/DI
Got this PUPpy on SALE @ AZ on 12/15
#989113 - 09/15/07 08:34 PM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: 06VtecV6]
teaelle Offline
Loc: Toronto, Canada
i would recommend Amsoil 0W-30, i use that in my TL type-S
works great on VTEC engine
#989114 - 09/15/07 10:22 PM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: teaelle]
wgtoys Offline
Loc: California
A synthetic 0W-20 is ideal for your situation. Contrary to popular beliefs, a 0W-xx oil is not "thinner" than a 5W-xx oil. The first number refers only to the oil's characteristics at very low temperatures.
If I lived in Minn. I would certainly run a 0W-xx oil in the winter. Mobil-1 0W-20 is an excellent choice for you. The only reason to switch to 5W-20 come summer time would be if it is easier to find or significantly cheaper.
For a warm climate like South Texas there is little advantage to the 0W-xx rating. It isn't going to hurt anything, but probably will not do much for your either.
#989115 - 09/15/07 10:56 PM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: wgtoys]
06VtecV6 Offline
Sweet, Imma go look for a jug of 0w-20 at WM! Thanks!
Edited by 06VtecV6 (09/15/07 11:00 PM)
#989116 - 09/16/07 12:35 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: 06VtecV6]
teaelle Offline
0W grade oil might evapourate a bit in hot weather, if u hit VTEC a lot
but it does give an extra kick when u rev past 5000rpm coz it ahs less drag
#989117 - 09/16/07 03:24 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: teaelle]
98LSC32V Offline
Loc: SF Bay Area
0W has nothing to do with hot weather!
#989118 - 09/16/07 04:27 AM Re: Acura 2003 CL-Type S--5 20 or 0 20 for Winter? [Re: 98LSC32V]
mechtech2 Offline
Loc: Chicago Area
Also, viscosity is a range, not an exact thickness.
Some 5-30s are thicker when hot than the same company's 10-30, for instance.
