Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
41 registered (Bandito440, 2015_PSD, bprimerano, Blkstanger, 66chevelle, 7 invisible), 776 Guests and 314 Spiders online.
58001 Members
66 Forums
249545 Topics
Page 1 of 5 1 2 3 4 5 >
#986234 - 09/11/07 04:39 AM Which spec 229.51 oil would you use?
groupIVnut Offline
Loc: Atlanta
I have just purchased a MB with a 3 liter diesel and the manual says to use a 229.51 spec oil. I goes on to say that the only approved oils are:
Mobil 1 ESP Formula M 5W-40
Valvoline SynPower MST 5W-30
ELF Solaris LSX 5W-30
What oil would you use?
Dieselfan
#986235 - 09/11/07 06:33 AM Re: Which spec 229.51 oil would you use? [Re: groupIVnut]
JHZR2 Offline
Loc: New Jersey
mobil1
#986236 - 09/11/07 05:21 PM Re: Which spec 229.51 oil would you use? [Re: groupIVnut]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I'm not sure how up to date this is:
http://www.whnet.com/4x4/oil.html
Scroll to the bottom.
What year is your MB?
#986237 - 09/11/07 05:29 PM Re: Which spec 229.51 oil would you use? [Re: Pablo]
groupIVnut Offline
Loc: Atlanta
All the oils listed in this site link are exactly what is in the manual for our vehicle. It is a 2008.
Which of these oils would you use and why?
Mobil 1 is the factory fill or at least there is a sticker on the radiator supt that is from Mobil 1
#986238 - 09/11/07 07:36 PM Re: Which spec 229.51 oil would you use? [Re: groupIVnut]
unDummy Offline
Loc: RI
I would use what is available locally at a reasonable price. This usually isn't the case with certain OE spec'd oils.
As long as the oil change interval is reasonable, any should perform perfectly. I would lean toward the thicker 40wts for southerners, and 30wts for northerners.
#986239 - 09/19/07 07:13 PM Re: Which spec 229.51 oil would you use? [Re: unDummy]
boxcab Offline
Loc: Auburn, Washington
The MB 229.51 spec is for a long-life, low-SAPS oil with high-temperature shear resistance.
I haven't been down to the local NAPA to see if in fact they have the 229.51 Synpower MST, but I have a case (12L) of Mobil 1 ESP 5W-30 from AV Lubricants and a case (12 qts) of Amsoil AFL 5W-40. The Elf Solaris LSX is available from the Performance Oil Store in 5L jugs.
I just ordered a case of ten oil filters from Germanfilters.com, as well as an extra fuel filter. The stealership sells the oil filter, if they even have them, for 2.5x as much. Who knows what they'd charge for the fuel filter?
Peruse this thread on Mobil 1 ESP 5W-30. Also, this thread with analysis results of Mobil 1 5W-30 ESP at 4000 miles. I sent in a 5K sample and should have the results back early next week.
Doug
'07 Jeep WK 3.0L CRD
#986240 - 09/20/07 03:58 AM Re: Which spec 229.51 oil would you use? [Re: boxcab]
OilGuy Offline
Loc: USA
Mobil has both a 5W-30 and a 5W-40 version of 229.51-approved Mobil 1 ESP - depending on what you want. AVlube.com is the only place I've seen either oil as well.
#986241 - 09/20/07 04:48 AM Re: Which spec 229.51 oil would you use? [Re: OilGuy]
buster Offline
Loc: NJ
Mobil 1
#986242 - 09/20/07 05:15 AM Re: Which spec 229.51 oil would you use? [Re: buster]
Drivebelt Offline
Loc: Alberta
Can't you use CI-4+ rated oils in North America?
Personally I would just use 15W-40 Delo 400. These Group II HDEO's rival the performance of synthetics.
#986243 - 09/20/07 07:02 PM Re: Which spec 229.51 oil would you use? [Re: Drivebelt]
OilGuy Offline
Loc: USA
No, that's why MB requires 229.51 for this application.
#986244 - 09/20/07 08:30 PM Re: Which spec 229.51 oil would you use? [Re: Drivebelt]
boxcab Offline
Sure, CI-4+ oils can be used in north America, just not in the MB OM642 turbodiesel.
There are NO dino oils, and few synthetics (at least in north America) that meet the MB 229.51 spec.
Doug
#986245 - 10/09/07 05:41 AM Re: Which spec 229.51 oil would you use? [Re: boxcab]
lkchris Offline
Loc: ABQ
Sticker under hood of new Mercedes cautions not to add ANY QUANTITY of non 229.51 oil.
Kent Christensen
Albuquerque
'03 New Beetle TDI, '06 E320CDI, '07 GL320CDI
#986246 - 10/19/07 11:44 PM Re: Which spec 229.51 oil would you use? [Re: lkchris]
JGmazda Offline
Loc: Arizona
I'd also add that Maxlife Synthetic meets the 229.51 spec. Great oil.
#986247 - 10/21/07 10:37 AM Re: Which spec 229.51 oil would you use? [Re: JGmazda]
mpersell Offline
Loc: Richardson, TX
Amsoil AFL meets the MB 229.51 spec. It's their 5w-40 European Car Formula
2004 Saab 9-5 ARC (New project)
2007 Dodge Ram FFV 8 years Amsoil AZO 0w-30 and bypass
Making a living with free software
#986248 - 10/22/07 07:33 AM Re: Which spec 229.51 oil would you use? [Re: mpersell]
Brons2 Offline
Loc: Austin, Texas
what is low SAPS? Just curious.
Mine: 2007 Kia Rondo LX 2.4 I4 5 pass, M1 HM 10w30, OEM filter
Hers: 2010 Rav4 Sport 2.5 I4, M1EP 0w20, OEM filter
