People running thru red lights. You ever follow th
by motor_oil_madman
05/03/16 08:30 PM
747-400 versus 747-8
by mjoekingz28
05/03/16 08:22 PM
14psi bypass pressure for small engines?
by motor_oil_madman
05/03/16 07:47 PM
'13 Wrangler 2.5" lift
by JXW
05/03/16 07:37 PM
group 7 v6128 ford 6.7 7k miles
by robo339
05/03/16 07:34 PM
Napa Synthetic
by wolf_06
05/03/16 07:34 PM
How do you guys do it?
by Duffyjr
05/03/16 07:04 PM
House electrical panel buzzing
by Mr Nice
05/03/16 06:15 PM
Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
122 registered (69GTX, andyd, AirgunSavant, 2002 Maxima SE, 01rangerxl, ABerns, 9 invisible), 1711 Guests and 319 Spiders online.
57779 Members
66 Forums
248427 Topics
#9739 - 11/09/02 07:54 AM Synthetic Oil vs API Service SL ILSAC GF 3
jsleesi Offline
Loc: Seattle, Washington
According to automobile technical information, the API Service SL ILSAC GF-3 is equally good oil as Synthetic oil????
If it is the case, why spend extra money on the oil? Can some one explain the pros and cons on the two types of oil?
Thanks
#9740 - 11/09/02 02:24 PM Re: Synthetic Oil vs API Service SL ILSAC GF 3
Patman Offline
Loc: Oakville, Ontario
I'm a bit confused as to what you are asking because synthetics are also classified under the API SL and ILSAC GF3 regulations too.
The dino oil may have just barely passed the tests, while the synthetic could be considerably above it.
#9741 - 11/09/02 03:43 PM Re: Synthetic Oil vs API Service SL ILSAC GF 3
widman Offline
Loc: Bolivia
if you read through all the threads on this board you will probably come to the conclusion that the SL oils are all very good, much better than others, with performance within the category improving as you increase the quality of the base oil (Group I to II, II to II+, II+ to III, and III to group IV & V blends; and lower the quantity of the VI improvers. Thus, one of the biggest advantages to group IV/V synthetics is in it's almost total lack of ability to shear down, and it's better pumpability at low temps.
#9742 - 11/09/02 03:54 PM Re: Synthetic Oil vs API Service SL ILSAC GF 3
Pablo Offline
Loc: Duvall WA - Pacific NW USA
[I dont know] I thinks we needs to see this " techinical information" you are talking about. While I think it is the underlying goal of API to improve motor oil with each revision, I think some nomenclature, middle logic and data got lost in translation here. As pointed out, synthetic oils can be SL as well.....API tests are just a minimum gate to pass.
[ November 10, 2002, 07:55 AM: Message edited by: Pablo ]
#9743 - 11/10/02 06:05 AM Re: Synthetic Oil vs API Service SL ILSAC GF 3
impala_sc Offline
Loc: South Carolina
perhaps they were referring to the fuel economy test? The ILSAC fuel economy tests compare an ILSAC GF3 candidate to a certain PAO oil.
#9744 - 11/10/02 10:12 PM Re: Synthetic Oil vs API Service SL ILSAC GF 3
Eiron Offline
Loc: Loveland, Colorado
quote:
I believe the Base Comparison oil is an oil which does NOT meet ILSAC specs. Both GF-2 & GF-3 specs require an *improvement* in fuel efficiency over the base oil.
jsleesi,
You're paying extra for even more durability. Yes, all GF-3/SL oils will be far superior to what was previously available, & if you can't get past the 3mo/3k mi change mentality, any SL oil is fantastic. Keep in mind that ILSAC tests are run for "normal" oil durations; their longest test is for 96 hrs, which is 2k-3k mi for me. I run my oil 3 to 5 times that, & the extra durability I get from ANY premium oil means:
1) I get better protection at the beginning of the oil's life
2) I get equal/better protection at the end of the oil's life
3) I spend less money overall
4) I spend less time changing oil
5) I dump out less oil (recycle, but it's still waste)
6) I get more cookies & beer 'cuz "all of the above"
Jeez... okay, now I can't get past #6 [Duh!]
What's the specific application/duration you're using it in?
#9745 - 11/12/02 07:46 AM Re: Synthetic Oil vs API Service SL ILSAC GF 3
impala_sc Offline
Loc: South Carolina
Correct. But the base comparison oil for the economy test is, I think, a PAO oil. That way the DINO ILSAC GF3 marketers could claim their oil "outperforms synthetic" aka PAO as long as they don't say how.
