Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
23 registered (Black_Thunder, car51, CLOVER, brslds, 3 invisible), 855 Guests and 10 Spiders online.
58632 Members
66 Forums
252385 Topics
#954683 - 07/31/07 06:53 AM Vinegar cleaning out a radiator?
82DMC12 Offline
Loc: Fargo, ND
Hey group,
I have a 1994 Lexus ES300 that has been getting hot lately. I bought new upper and lower hoses, clamps, radiator cap, and thermostat. I started taking parts off to replace these items, and until I decided I might as well clean the radiator fins too. I pulled the radiator out and hosed it off, then ran water through the rad. No gunk came out, just water. However, when I looked inside, I could see white deposits inside the tubes. I guess that's the calcium I hear about.
This radiator is made of aluminum with plastic end caps. It is not leaking (yet). I figure since it's probably toasted, I might as well try to clean it out since I have nothing to lose. I have read on the internet that filling a radiator up with vinegar will dissolve this stuff rather easily, since vinegar dissolves mineral deposits. So right now, my radiator is soaking in vinegar.
Has anyone actually done this and had success? Did the radiator leak afterwards? I did see that copper radiators should not be treated this way.
If this doesn't work, I'll see about getting it steamed out before I buy a new one ($300!)
Andy
#954684 - 07/31/07 07:06 AM Re: Vinegar cleaning out a radiator? [Re: 82DMC12]
Quest Offline
Loc: beaver land EH?
vinegar is too weak (typically 3% acetic acid)!
My recommendation is to go get some Prestone radiator flush that is basic (alkaline) and will not eat through your aluminium radiator core for it's much more potent than soaking in vinegar.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#954685 - 07/31/07 10:06 AM Re: Vinegar cleaning out a radiator? [Re: Quest]
The Critic Offline
Loc: Walnut Creek, CA
Prestone Radiator Flush isn't very strong. Use Prestone Super Radiator cleaner, it worked quite well for me. Do run it for the full 4-6 hr over a week.
If you are desperate, you can always try some TSP...but it might destroy your radiator. But hey, if you are going to get rid of it anyway...
11 Prius - 133k - M1 EP 0w20/OE
07 Accord 2.4 - 112k - M1 5w20/Fram Ultra Filter
10 Altima 3.5 - 35k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#954686 - 07/31/07 08:13 PM Re: Vinegar cleaning out a radiator? [Re: 82DMC12]
Tempest Offline
Loc: Las Vegas NV
RMI-25. Check the coolant section.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#954687 - 08/01/07 01:07 AM Re: Vinegar cleaning out a radiator? [Re: 82DMC12]
gomes512 Offline
Loc: Chicago, IL
Vinegar? Yeah that is to weak. I use Muriatic acid found at hardware stores. It's basically hydrochloric acid, I dilute it to 50/50 with water and dump it then run it for an hour or less. Then I run the system twice more with distilled water to fully flush out the acid and dissolved minerals.
I've done this in three different vehicles. '94 grand cherokee, '00 Chrysler sebring, and a (can't remember year '98 or something) Mercury sable.
I've had great results, especially with the Jeep, since previous owner used tap water to dilute coolant instead of distilled water.
Have had no problems since, I dump the radiators of the two above vehicles at scheduled intervals and all I see is green Prestone come out and I put new stuff in.
#954688 - 08/01/07 01:46 AM Re: Vinegar cleaning out a radiator? [Re: gomes512]
pidster Offline
Loc: ontario canada
Just replace the radiator. Nothing else will give the same results if its that gunked up.
2010 Ford Ranger Sport 4x4, 4.0L Manual 5 speed
All Motorcraft Filters
Current fill: Mobil 1 0w40 with Lubro Moly MoS2
#954689 - 08/01/07 04:06 AM Re: Vinegar cleaning out a radiator? [Re: pidster]
widman Offline
Loc: Bolivia
Use the radiator cleaner. Too many different metals to play with, The Prestone or Winns stuff should clean it up while circulating. I've cleaned out some really messed up radiators that way
Richard's Car Restorations
#954690 - 08/01/07 11:33 PM Re: Vinegar cleaning out a radiator? [Re: widman]
shoz123 Offline
Loc: Illinois
Vinegar will work and the hotter the better. You don't want to use it in copper because it will dissolve the lead in the solder.
HCL and aluminum will tear things up fast.
