Ugly New Prius #2
by AirgunSavant
08/28/16 08:32 AM
Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
73 registered (4WD, 09_GXP, 2010Civic, 2015_PSD, 2009Edge, 2004tdigls, 5 invisible), 1268 Guests and 26 Spiders online.
58943 Members
66 Forums
253659 Topics
Page 1 of 2 1 2 >
#954568 - 07/31/07 05:00 AM MS 6395 -- What oils meet it?
HawkeyeScott Offline
Loc: El Oeste
I searched this spec. but found nothing on it.
Wife's new Pacifica (4.0L V6) requires this MS 6395 spec. I have a garage full of SM rated Quaker State dino, Havoline dino (old recipe), Valvoline DuraBlend, as well as two varities of Quaker State synthetic. Only one (one of the Q.S. synthtics) says it meets this requirement.
What about this MS 6395? Am I right in assuming that since the other oils don't say anything about it, they don't meet it? Or is it a given that they do? Thanks gents.
-Scott
#954569 - 07/31/07 06:21 AM Re: MS 6395 -- What oils meet it? [Re: HawkeyeScott]
N2OIL Offline
Loc: Aviation Capital
VALVOLINE PREMIUM CONVENTIONAL MOTOR OIL
Valvoline Premium Conventional multigrade motor oils are formulated with advanced additive technology and highly refined, premium quality basestocks that protect todays engines against undesirable deposits, contamination, and viscosity and thermal breakdown under severe service conditions. They meet the performance requirements of virtually all naturally aspirated, turbocharged and supercharged gasoline fueled passenger cars and light duty trucks, including European and Japanese vehicles*.
The Valvoline Premium Conventional Motor Oil Advantage
High Temperature Protection: Resists breakdown in the most severe engine environments.
Low Temperature Protection: Flows easily at low temperatures, reducing wear at start-up.
High Detergency: Fights formation of sludge and varnish deposits that reduce engine life.
Wear Protection: Contains anti-wear additives that dramatically reduce engine wear. Meets European and Japanese
Wear requirements.
Turbo Approved: Provides excellent protection to critical turbo unit components.
Fuel Economy: Improves fuel economy in new and old vehicles.
Approvals/Performance Levels
Viscosity Grade/Other
API SM/SL
SAE 5W-20 SAE 5W-30 SAE 10W-30
ILSAC GF-4 & GF-3
Energy Conserving
DaimlerChrysler MS-6395M
#954570 - 07/31/07 06:24 AM Re: MS 6395 -- What oils meet it? [Re: N2OIL]
N2OIL Offline
Dura blend meets it as well 5W/20, 5W/30, 10W/30
#954571 - 07/31/07 02:25 PM Re: MS 6395 -- What oils meet it? [Re: N2OIL]
vronline Offline
Loc: Kansas
Castrol GTX does as well. Just do a search for the spec on Google. It looks like there are several others you can easily spot.
#954572 - 07/31/07 03:25 PM Re: MS 6395 -- What oils meet it? [Re: HawkeyeScott]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
All the Amsoil XW-30 and XW-20 PCMO's meet MS-6395.
#954573 - 07/31/07 06:45 PM Re: MS 6395 -- What oils meet it? [Re: Pablo]
Herdfan Offline
Loc: West Virginia, USA
I was looking at the same thing, here is what I know so far. I am sure there are more, but have not generated a full list yet.
This is for 5w-20, 5w-30 and 10w-30 weights.
Valvoline Durablend
Valvoline Conventional
Pennzoil
Pennzoil Platinum
Mobil 1
Mobil 1 EP
Mobil 5000
Mobil 7500
Note: Castol GTX and Syntec state they they "meet the fill requiremnts of Ford, Honda and Chrysler but while it directly references the ford spec, it does not specifically state the 6395 Chrysler spec, or the honda for that matter.
#954574 - 07/31/07 10:03 PM Re: MS 6395 -- What oils meet it? [Re: Herdfan]
BennyL Offline
Loc: Toronto, Canada
i'm pretty sure i just read on the schaeffer's site that their 7000 series 5W-30 meets that standard too.
#954575 - 07/31/07 10:24 PM Re: MS 6395 -- What oils meet it? [Re: BennyL]
badtlc Offline
Loc: KC
Schaeffers 7000 5w30 and 10w30 both meet it.
#954576 - 07/31/07 10:51 PM Re: MS 6395 -- What oils meet it? [Re: badtlc]
Loc: El Oeste
Thanks guys. Nice work Herdfan. I too had resorted to looking at each website to see what meets it. Have you come across some that are different letters following the numbers, like 6395N or 6395M? That too threw me for a loop.
#954577 - 08/01/07 01:00 AM Re: MS 6395 -- What oils meet it? [Re: HawkeyeScott]
Herdfan Offline
I have, bet I can tell from reading on here and a couple of Dodge and Jeep sites, the M/N indicates revisions to the cold temp. flow requirements.
I normally am not so picky about oil, but my 2007 4.7 Jeep XK is one of the Chryco vehicles that went from the 5w-30 to the 5w-20 recommendation after the 2006 model year without any changes to the engine. This concerns me a little, so I figured I should stay within the 6395 if I am going to run the 5w-20, since I really do not think it is thick enough for that V8. I am running PP 5w-30 right now, but will run 5w-20 in the near future.
#954578 - 08/01/07 03:42 AM Re: MS 6395 -- What oils meet it? [Re: HawkeyeScott]
Buick92 Offline
Loc: Pullman Wa
I know Castrol GTX 5w-20 meets it, their web site states it, I also believe that chevron and havoline 5w-20's also meet it.
#954579 - 08/01/07 03:52 AM Re: MS 6395 -- What oils meet it? [Re: Buick92]
Panzerman Offline
Loc: Port Orange, Florida
I think just about any oil in any 5w20, 5w30 ,10w30 and some 10w40, meet this spec. I think its one of the older, easier to meet specs that there is.
2007 Ford F-150 FX-2 76,000
2007 Ford F-150 FX-4 203,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 70,000
2002 Lincoln Continental 155,000
#954580 - 08/01/07 07:13 AM Re: MS 6395 -- What oils meet it? [Re: Panzerman]
ewetho Offline
Loc: Kankakee, IL
When I first got my 04 Neon I was looking into this heavily. I actually got the latest spec from Mopar and it was with one exception was LINE for LINE GF-4. So SL GF-3 with MS-6395 was oil that met GF-4 before it was finalized.
Just before the release of the 5000,7500, and 15000 Mobil stuff they had a reformulated Drive clean that was SL GF-3 MS-6395. One of the few at the time. Then once I new it was GF-4 which came out in force just after that, it is not worth the time to worry about any more.
So get yourself any SM GF-4 oil and be done with it.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#4036442 - 03/12/16 01:11 PM Re: MS 6395 -- What oils meet it? [Re: HawkeyeScott]
dakota99 Offline
Loc: indiana
MS-6395 isn't a very stringent spec. Pretty much anything that is SN / GF-5 meets it.
#4036661 - 03/12/16 06:31 PM Re: MS 6395 -- What oils meet it? [Re: Herdfan]
zuluplus30 Offline
Loc: Fly-Over Country
Originally Posted By: Herdfan
Mobil 1
Mobil 1 EP
Neither of the above are certified to meet MS-6395. Not that they don't pass it with flying colors, but ever since EM had a falling out with FCA, EM has not actively sought MS-6395 approval for Mobil 1.
As I recall, GTX & Edge don't list it on the bottle but if you go through the PDS sheets online they do.
Page 1 of 2 1 2 >
