Car threw a P1300 "igniter circuit malfunction" code this morning. Car is a 1995 Toyota Tercel, DIS ignition system with two coils & no distributor. I've noticed a split-second misfire a couple of times when hammering on the gas after upshifting.
Are these things known to wear out when they get old, or is it more likely a wiring issue? I can't simulate the problem by rocking connectors or jiggling wires. It has a good clean ground.
Any other symptoms I can watch for? Is this likely to get worse fast?
Any input appreciated.
