Causes of steering wheel shudder
by buck91
08/25/16 10:14 PM
Brand new Focus ST...
by Striker
08/25/16 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
08/25/16 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
08/25/16 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
08/25/16 08:35 PM
Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
08/25/16 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
08/25/16 07:50 PM
Did I goof?
by mv6845
08/25/16 07:33 PM
Opinions on Indestro tools?
by Vern_in_IL
08/25/16 07:25 PM
Nice bear sighting
by car51
08/25/16 07:05 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
76 registered (2015_PSD, Anduril, AMC, AP9, 2165, 2004tdigls, 2 invisible), 1327 Guests and 6 Spiders online.
58926 Members
66 Forums
253564 Topics
#915994 - 06/07/07 09:53 AM Seafoam for sludge removal?
i_r_teh_noobz Offline
Loc: Ohio
Well, after pulling the PVC valve out of the 1.6L Nissan (116k miles) that I bought about a month ago, I think its safe to say that my engine needs a good cleaning. The engine side of the valve was a solid cake of sludge, and the vacuum hose was full of crust. I have yet to remove the valve cover, but I'm pretty sure it doesn't look very good.
I can't find Auto RX at my local parts stores, but Seafoam is pretty easy to find. Will this do the trick? Should I just run it in from a vacuum line, or do I need to try something else?
1993 Nissan Sentra XE
1983 Oldsmobile Toronado
#915995 - 06/07/07 10:10 AM Re: Seafoam for sludge removal? [Re: i_r_teh_noobz]
KC Strip Offline
Loc: KC Metro
FYI -
You won't find AutoRx in any parts store. I believe Frank said it is too cost prohibitive and then there's the training involved with each store's staff.
My experience with AutoRx has been fantastic! It's done a great job on both of our vehicles (Olds 3.1L with 180k & Suburban 5.7L with 110k). In fact, Frank's running a Father's Day special, so check out http://www.auto-rx.com for more details.
"A good reputation takes a lifetime to build and a moment to ruin."
#915996 - 06/07/07 01:34 PM Re: Seafoam for sludge removal? [Re: i_r_teh_noobz]
Merkava_4 Offline
Loc: Clovis, CA
I'd just pull the valve cover and just dump some lacquer thinner on the head and swish it around with a parts brush. You'll see the sludge liquify instantly. After that you'll definitely be needing an oil change.
#915997 - 06/07/07 03:42 PM Re: Seafoam for sludge removal? [Re: Merkava_4]
Donald Offline
Loc: Upstate NY
They ship Auto-Rx quickly, so I would order enough for two treatments and wait the day or two it takes to arrive.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#915998 - 06/07/07 07:25 PM Re: Seafoam for sludge removal? [Re: Donald]
Cicero17 Offline
Loc: Winlock, Washington
We used Seafoam in my son's 2000 Camry. We put 1/3 can in the oil, 1/3 in the gas tank and I still have the other 1/3. When we changed the oil a couple of hundred miles later at 3K on the oil, the oil was very dirty. The dipstick had a new shiny appearance. I don't think his engine had much sludge in it, but it took off the varnish from what I can tell. The oil was Supertech synthetic 5w-30. Yes, we still have some Walmart product around from my unenlightened days.
Don
Never give a inch
#915999 - 06/07/07 11:57 PM Re: Seafoam for sludge removal? [Re: Cicero17]
Donald Offline
Loc: Upstate NY
I would NOT add Seafoam to the oil. Its mostly a solvent and good for the fuel system but not for lubricating.
#916000 - 06/08/07 12:14 AM Re: Seafoam for sludge removal? [Re: Donald]
wileyE Offline
Loc: Kitsap, WA
I got talked into putting a bottle in a auto transmission that was having some shifting issues. It knocked all kinds of stuff loose from every nook and cranny. The filter caught most of it but I found junk in the valve body when I cleaned it out. IMO, most the junk I knocked loose was better left hiding in corners.
#916001 - 06/08/07 07:50 AM Re: Seafoam for sludge removal? [Re: Merkava_4]
M1Accord Offline
Loc: Lost
Would this cause the sludge to partly dissolve and drain back down toward the lower parts of the engine and block critical oil passage in the process?
#916002 - 06/08/07 01:24 PM Re: Seafoam for sludge removal? [Re: M1Accord]
Merkava_4 Offline
Loc: Clovis, CA
Not if you follow up with some mineral spirits. The mineral spirits won't evaporate easily like the lacquer thinner will; it'll keep the sludge liquified until you flush it out with a 20 minute OCI.
#916003 - 06/10/07 06:16 AM Re: Seafoam for sludge removal? [Re: Merkava_4]
askani79705 Offline
Loc: midland tx
rotella T 5w40 and MMO.
2014 Subaru Forester Wix 57055 0w20 QSUD.
97 Ford 150 MC FL820s Mobil High Mileage 5W30
#916004 - 06/10/07 07:35 AM Re: Seafoam for sludge removal? [Re: askani79705]
rsylvstr Offline
Loc: Oneida County, NY
I'd run a few ARX cycles....I'm halfway through the first cycle on the F150 and civic and the second on the galant...love the mileage increase.
Rob / Doc Master Chief
2001 F150 SCrew Lariat 4X4 5.4L, 4R70W, LS 9.75" 3.55
2012 Altima SL that my wife doesn't want me to touch.
#916005 - 06/10/07 08:04 AM Re: Seafoam for sludge removal? USE NOTHING NOW [Re: rsylvstr]
unDummy Offline
Loc: RI
Don't invest a penny into any OIL additives until you are sure that the engine runs well.
My recommendation is a bunch of 2-3k OCI's with whatever oil you want to use. If after ~10k miles and all sounds well, then consider something.
If you truly have sludge, your timing chain/tensioners are junk already.
Also, since I've seen some failed filter bypasses on older Nissans that use the PH3682-sized filter, consider the bypass-equipped PH3600.
