Gates vs. Bando - Tensioner Position (Pics)
by The Critic
05/05/16 03:19 AM
Cel P0170&P0172 coming on & off
by Rohan
05/05/16 01:44 AM
Reccomend me how often to wax my car
by FordCapriDriver
05/05/16 12:55 AM
Space-X and Government Subsidies
by HTSS_TR
05/05/16 12:13 AM
New BP Fuel??!
by SubieMovie
05/04/16 11:30 PM
VWB for 2015 F150 5.0
by leeaspell
05/04/16 11:04 PM
Polaris Slingshot
by LoneRanger
05/04/16 10:02 PM
Building a pole barn
by SVTCobra
05/04/16 09:44 PM
Hemorrhoids ?
by Merkava_4
05/04/16 09:40 PM
Well, I jumped on the ecoboost bandwagon...
by tomcruise
05/04/16 09:18 PM
2016 Audi S3 - EA888 Gen 3 - Factory Fill - 2007mi
by agpatel
05/04/16 09:16 PM
Can you live without credit cards?
by motor_oil_madman
05/04/16 09:04 PM
02Maxima, xlittoninjax, Jamer, johaiti, Danielbaja
57803 Registered Users
15 registered (DaleRider, FordCapriDriver, cobra7279, bbhero, 2 invisible), 0 Guests and 1 Spider online.
57803 Members
66 Forums
248491 Topics
#911676 - 06/01/07 12:48 AM Looking for GL-4 rated gear oil in the 85w-140 ran
Crusader Offline
Loc: North Idaho
I have a Troy-Bilt Horse Rototiller that calls for GL-4 . . . NOT GL-5 This is due to the bronze shear gear and supposedly the additives used in GL-5 gear lube are hostile to these Bronze parts. This is hearsay but I've heard that Synthetic Gear lube with a GL-5 rating is NOT harmful. Such as Mobil1 and Royal purple?
Now to confuse matter worse I called Troy-Bilt and they now call for GL-1 85w-90? Now if GL-1 85w-90 is ok why not GL-4 85w-90? What's the difference?
So what is the difference between GL-4 & GL-1? Is Synthetic GL-5 bronze gear friendly?
I use the Troy-Bilt Commercially and it sees very heavy use and the gear oil needs to be changed ASAP
Thanks
2 Honda Civics, 3 Toyota 4x4's and a KLR650
Over 1 million miles combined
And many air cooled 2 and 4 stroke engines
gladiator
#911677 - 06/01/07 01:49 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I use synthetic 75W-140 in mine. No issues.
I think you just want to avoid generic old fashioned sulfur loaded conventional GL-5.
#911678 - 06/01/07 02:03 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Pablo]
Crusader Offline
Loc: North Idaho
Pablo Thanks for the reply.
Just noticed this quote linked below:
" . . . Mobil 1 Synthetic Gear Lubricant LS 75W-140 combines wax-free synthesized hydrocarbon base oils and a specially designed extreme-pressure, limited-slip, sulfur-phosphorous additive system including the SuperSyn antiwear technology to provide a significantly higher level of performance in rear axles and differentials . . ."
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMoMobil1_Synthetic_Gear_Lubricant_LS_75W-140.asp
gladiator
#911679 - 06/01/07 02:14 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
Tempest Offline
Loc: Las Vegas NV
Pretty much all of the gear lubes are sulfur-phosphorous based. There are exceptions, though. Modern gear oil packages have chemistries to prevent corrosion problems.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#911680 - 06/01/07 04:46 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Tempest]
Crusader Offline
Loc: North Idaho
So is there a GL-5 gear lube that is NOT rated for GL-4 applications? What is really confusing . . . Troy-Bilt is now calling for GL-1 rated gear oil intead of GL-4?
Just so you know Troy-Bilt was bought out by MTD. Troy-Bilt had to pay big bucks on Chipper Shredder injury at least that's what I've been told thus they lost their shirts.
gladiator
#911681 - 06/01/07 05:08 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
gtx510 Offline
Loc: CA
Redline 75W140NS ? It's GL-5+
http://www.redlineoil.com/products_gearl...mp;categoryID=6
GL-1? Do you mean MT-1?
#911682 - 06/01/07 06:58 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: gtx510]
Crusader Offline
Loc: North Idaho
Found this @ Please do not link to sales pages of non-site sponsors. Thanks.
" . . .Severe Service Performance
Max-Gear® exceeds Eaton's stringent GL-5 / MIL-L-2105D Gear Oil Specs. Max-Gear® also is safe for GL-4 applications or bronze synchro gears. . .'
Looks like I found my Gear oil!
Edited by JHZR2 (06/01/07 08:10 AM)
gladiator
#911683 - 06/01/07 07:24 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
Pablo Offline
I fail to see why you ignored Amsoil in your searching. I thought I gave you decent advice:
Quote:
Can also be used in axles where an API GL-4 lubricant is recommended.
Support a BiTOG site sponsor!
#911684 - 06/01/07 08:49 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
Touring5 Offline
Loc: Indiana
This post got my attention because I'm planning on replacing the (original) transmission oil in my 15-year old "Pony" model. My manual says 85W-140 GL-3 or GL-5 for top-off, but only GL-3 for refills. I bought some "Accel" 85-140 at AA, but later noticed it's GL-5. Can anybody confirm whether it'd be OK to refill with this oil or should I keep looking for the GL-3 oil. I didn't know if changes in lubes since the early nineties would make this oil OK for use. I'm not at all well versed in Gear lubricants and find this GL rating a bit confusting...
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
#911685 - 06/01/07 11:36 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Touring5]
unDummy Offline
Loc: RI
If you use a GL5 fluid, you'll just have to practice a more reasonable change interval.
If you're too lazy to change your gear oil on a regular basis, then don't use the GL5 cheapo store brand fluid.
AFAIK, the entire range of RP Maxgear is GL4/GL5 safe.
If you do use a GL5 fluid, stick with the boutique quality fluids. They'll be using the least reactive additive packages and best buffering agents that will eliminate the so-called GL5 sulfur issues(which IMO is severly overhyped).
You'd have to use the fluid beyond its usefull life or get moisture in it, for it to be a problem.
#911686 - 06/02/07 09:30 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: unDummy]
mechtech2 Offline
Loc: Chicago Area
If a sauce says that it is dual rated as a GL4/GL5, you can safely use it.
#911687 - 06/04/07 07:12 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: mechtech2]
Touring5 Offline
Loc: Indiana
Thanks for the replies. I returned the generic GL-5 rated stuff and found 140W GL-4 rated oil (this is the weight Troybilt mentions for refills). I take it that the GL-4 lube should be OK - since my manual specifies GL-3?
Sorry for prolonging this thread, but I'm trying to be cautious about a subject I'm pretty ignorant about...
FIRST LAW OF DEBATE
#911688 - 06/12/07 06:58 AM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Touring5]
Crusader Offline
Loc: North Idaho
I thought I was set on Royal Purple or even Amsiol extreme duty gear oil or possibly Mobil1 however . . . I found some 85w 140 gear oil under the brand name of COSTAL, from AutoZone, it services GL-5, GL-4 and . . . . GL-3 I figured I'd run this since I now have discovered a leaking wheel seal that isn't going away.
My question is what makes this a GL-3 rated gear oil? You don't see that spec very often? Also states limited slip for "top off only" - Is the "stuff that is good for limited slip differential bad for bronze tyranny parts or would it be good?
Thanks for all the input
gladiator
#911689 - 06/12/07 07:15 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Crusader]
Touring5 Offline
Loc: Indiana
You're right about GL-3 not being mentioned in product labelling or literature. I wondered if GL-4 actually superceded it. Although my owners manual lists GL-3 140W for refills, Troybilt's website says GL-4. (see: http://troybilt.custhelp.com/cgi-bin/tro...amp;p_topview=1 I found Lubrimatic 140W GL-4 at O'Reilly's and put it in last weekend.
As for the leak around the axle(s), mine has done that for years. I asked a dealer about getting it repaired and he said it would eventually leak again after the seals are replaced...
I never figured that simple maintenance on a tiller would be so complicated - I even found that the spark plug listed in the owner's manual differed from the one originally installed and listed in the B&S engine manual
FIRST LAW OF DEBATE
#911690 - 06/12/07 08:16 PM Re: Looking for GL-4 rated gear oil in the 85w-140 [Re: Touring5]
Crusader Offline
Loc: North Idaho
I was able to find GL-4 only under the Sta Lube brand name at a local NAPA however it was rated 80w-90. Now that Troy-Bilt calls for a GL-1 in the 80w-90 range what is the difference of viscosity ratings.
Why is the viscosity for GL-4 recommended at 80w-140 yet a GL-1 gear oil is ok at a lower weight of 80w-90?
gladiator
