BIBLE STUDENT GONE?
by Eddie
06/25/16 06:23 AM
Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
54 registered (Bandito440, AandPDan, Astro_Guy, andyd, 2010Civic, bbhero, 7 invisible), 1078 Guests and 16 Spiders online.
58257 Members
66 Forums
250770 Topics
Page 1 of 3 1 2 3 >
#899381 - 05/13/07 08:34 PM Honda GCV160 oil draining proceedure
philipsearcy Offline
Loc: Indianapolis, Indiana
Just purchased a push mower with Honda GVC160 OHC engine. Mowed only once but I love this engine. I looked at the bottom of the engine and I could not find an oil drain plug. I looked in the manual and they show that you remove the dipstick and tip the mower to drain from the fill tube. I think this method stinks. Am I missing the drain plug or has someone here installed a drain plug to make this a better process? Thank you. Philip.
'04 F250SD 5.4, '08 Honda Fit 1.5, '07 Mazda5 2.3, '09 Kubota L3940, '50 Ford 8N tractor, '61 Ford 6000 tractor
#899382 - 05/13/07 11:43 PM Re: Honda GCV160 oil draining proceedure [Re: philipsearcy]
UncleS2 Offline
Loc: Far North East Texas
Yup- no drain plug on my Honda gcv160 engine either. As much as I'd prefer to have a drain plug, it would probably be a lot more trouble to install one than it's worth- at least to me. I just let the mower sit a few minutes for the oil to drain back into the sump after running it, then remove the filler-cap/dipstick & tilt mower on its side. Works well enough, & since I use mine only for trimming, one oil change a year is gonna be overkill in a big way.
Still, it *does* go against the grain. But I don't want to have to dismantle the engine to prevent, or clean out, all those aluminum shavings that drilling & tapping produce.
If you do install one, let us know & post pix, will ya?
The Emperor Has No Clothes.
Pay no attention to that man behind the curtain.
Sad to say, Bob, Terry, & Johnny were 100% right.
#899383 - 05/14/07 12:08 AM Re: Honda GCV160 oil draining proceedure [Re: philipsearcy]
flatlandtacoma Offline
Loc: Illinois
Congratulations on your purchase. Draining through the fill tube works just fine. What do you think stinks about it?
'99 Tacoma 5VZFE 125k miles
'03 Civic Si K20A3 135k miles
JD LT160 Kohler CV460 510 hours
#899384 - 05/14/07 12:22 AM Re: Honda GCV160 oil draining proceedure [Re: philipsearcy]
GrtArtiste Offline
Loc: Ohio
Be very careful not to overfill it or it will leak out of the governor pivot arm. Start with about 16 ounces, then check it carefully as you slowly top it off.
GrtArtiste
#899385 - 05/14/07 03:40 AM Re: Honda GCV160 oil draining proceedure [Re: GrtArtiste]
punisher Offline
Loc: snowblind in TX
Just make sure the carb has been run dry before tipping the mower.
#899386 - 05/14/07 04:09 AM Re: Honda GCV160 oil draining proceedure [Re: punisher]
Bill Kapaun Offline
Loc: Oregon
Why?
I've never heard of a Honda engine having any problems regarding this.
Apparently you have some personal experience?
#899387 - 05/14/07 06:22 AM Re: Honda GCV160 oil draining proceedure [Re: Bill Kapaun]
oily boyd Offline
Loc: WI
No need to run the carb dry IF you are tilting mower to change the oil. Problems come when tipping the CARB side down.
16 oz is too much to refill this engine. Measure the oil that comes out; start with that as your initial fill. I predict you will get about 14 oz.
Kind Regards,
Boyd
#899388 - 05/14/07 05:25 PM Re: Honda GCV160 oil draining proceedure [Re: flatlandtacoma]
My opinion, I would rather put mower on two milk crates and drain the oil from the bottom. Now I have not changes the oil yet, I have three more tanks of fuel to run through it to get to my 5 hour initial oil change, but I think tipping it will be messy, possibly getting oil on the engine and deck. I think all of the oil may not drain out through the filler tube. I am concerned about spilling fuel out of the tank or flooding the carburator, so I will run it out of fuel before I drain oil. I think a plug on the bottom would be much more simple. Philip.
#899389 - 05/14/07 07:12 PM Re: Honda GCV160 oil draining proceedure [Re: philipsearcy]
kkreit01 Offline
Loc: Olathe, KS
This is the way I've always drained my oil on my old 3.75 B&S. I just bought a new Cub Cadet. It has a drain plug, but the plug comes out the side. There's nowhere for the oil to go -- other than all over the mower deck? I would still have to tilt it on it's side (some) to use the drain plug.
2014 Dodge Durango Limited AWD 3.6: 5w20 PP/Napa Gold filter
2014 Ford Edge SEL FWD 3.5: Factory Fill
#899390 - 05/14/07 09:10 PM Re: Honda GCV160 oil draining proceedure [Re: kkreit01]
yeehaw1960 Offline
Loc: Nebraska
Just have a small coffee can ready to catch the oil. If the engine is warm, it speeds things along immensely.
#899391 - 05/14/07 09:45 PM Re: Honda GCV160 oil draining proceedure [Re: philipsearcy]
Loc: Illinois
I've never had a problem with this method. I get about 15 oz out through the fill tube directly into a coffee can. I do see that you could let it drip longer up on the milk crates to maybe get another 1/2 ounce or so.
Always tip with the carb side up in the air and you won't spill a drop. No need to empty the fuel. The fill tube is on the correct side so you don't have to tip the carb side down and have fuel run out all over the place.
#899392 - 05/14/07 09:55 PM Re: Honda GCV160 oil draining proceedure [Re: Bill Kapaun]
punisher Offline
Quote:
Why?
First time I changed my oil I didn't run the carb dry and it was a bear to start afterward, and when it did it smoked like crazy. The next oil changes and blade change went without a hitch with the carb dry.
Just a habit I got into.
#899393 - 05/14/07 10:40 PM Re: Honda GCV160 oil draining proceedure [Re: punisher]
Craig in Canada Offline
Loc: Toronto-ish, Canada
My Honda mower with GXV160 has a drain plug, but it's inaccessible for changes (right against the deck) and the manual says to tip to drain.
The carb doesn't leak if you tip in the direction of the oil filler tube. Never had a problem. All the oil comes out just fine, no problem hitting a collection device all by myself etc... Frankly it's neater to drain than my GCV160-powered pressure washer and electric compressor. I find I can just put my usual used oil collection tray beside the mower and tip to pour...
Craig.
#899394 - 05/15/07 03:16 AM Re: Honda GCV160 oil draining proceedure [Re: punisher]
Bill Kapaun Offline
Loc: Oregon
Quote:
Quote:
Why?
Is it a HONDA?
IF so, you seem to be the only one that has a problem!
#899395 - 05/15/07 07:07 AM Re: Honda GCV160 oil draining proceedure [Re: Bill Kapaun]
vronline Offline
Loc: Kansas
I've had my Honda for about 10 years... Drain the oil by tipping on its side into a small bucket as the owner's manual states. Mine holds .63 qts. (about 20 oz.) of oil. Read your owner's manual for exact procedure and oil capacity.
By the way, it's really easy!
Page 1 of 3 1 2 3 >
