Long Life H7 Bulb Choices
by The Critic
12 minutes 16 seconds ago
Pennzoil dexos good for 5k?
by jimmy87
43 minutes 26 seconds ago
Mobil1 5W-20, 7948 miles, 2010 Mazda5 2.3L
by Fission
Yesterday at 11:51 PM
Top Tier vs. Cheapest gas + Techron
by vinu_neuro
Yesterday at 11:50 PM
Walmart is a great place to buy tires
by tommygunn
Yesterday at 11:24 PM
Suspension repair gone bad.......
by cutchemist42
Yesterday at 11:17 PM
Check it out!
by jimmy87
Yesterday at 11:16 PM
Rolls Royce XWB Engine
by expat
Yesterday at 11:15 PM
Its Time To Replace Moms Battery On The 2004 MGM
by crazyoildude
Yesterday at 10:48 PM
UCL data?
by GMorg
Yesterday at 10:05 PM
2004 TrailBlazer Front Diffy Shaft Seal
by MolaKule
Yesterday at 09:59 PM
Valley Stream, LI NY Wal-Mart Mobil 1
by hardcore302
Yesterday at 09:50 PM
Dcwilliams29id, tonydi, Born2Run, Boost00, TXCarGeek
45892 Registered Users
53 registered (babyivan, Brule, 4ever4d, 190E26FTW, Art_Vandelay, 2010_FX4, 5 invisible), 739 Guests and 240 Spiders online.
45892 Members
64 Forums
195280 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#894299 - 05/06/07 04:24 AM If 2-Stroke Oil Is Used in a 4-Stroke Engine...
XB70 Offline
Loc: USAF Museum
...what harm might have been done and what corrective measures need to be taken?
#894300 - 05/06/07 04:43 AM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: XB70]
clembrewer Offline
Loc: Upstate NY
Not a bit of harm. I use 2-stroke mix gas in everything. It may smoke a tiny bit more than regular gas. Remember, the 2-stroke oil is meant to be burned in a combustion chamber.
#894301 - 05/06/07 05:15 AM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: clembrewer]
Quest Offline
Loc: beaver land EH?
If you happen to have gas that is laden with 2T oil and you try to burn it in 4-stroke engine, it won't harm it esp. low tech lawnmower engine such as B&S, etc.
my 2c's worth.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#894302 - 05/06/07 05:20 AM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: clembrewer]
XB70 Offline
Loc: USAF Museum
Yes, I've heard/read about people using a 2-stroke's gas/oil mix as their fuel in a 4-stroke, and I know about the 2-stroke's oil being burned, but as the story that prompted this question was told to me, 2-stroke motor oil was used in the crankcase of a 4-stroke engine. The fuel was plain old pump gas.
Also, the engine was overfilled; from what I was told, the smoke was rather impressive and decimated the local mosquito population. The question is, how might the engine have been harmed, and is changing the oil and cleaning the plug about all one can do in that situation?
Sorry if my original question was vague.
#894303 - 05/06/07 07:21 AM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: XB70]
Johnny Offline
Loc: Retired | Wausau, WI
First off 2-cycle oil has solvent in it to help it mix with gasoline. This in itself thins the oil. The 2-cycle does not have any of the additives in it that a 4-cycle engine needs. Depending on how long this engine was run, the best thing to do it get rid of the 2-cycle oil and fill it with the proper amount of recommended oil and see what happens. Unless the spark plug is fouled there is probably no need to do anything with it. Under the worse case the cylinder walls are scared and the bearings are worn badly.
#894304 - 05/06/07 04:10 PM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: XB70]
Craig in Canada Offline
Loc: Toronto-ish, Canada
Your question is not specific enough and people are answering different questions.
Where, specifically, is the 2-stoke oil being used in the 4-stroke? In the crankcase as motor oil? Or are you referring to the use of 2-stroke premix as fuel for a 4-stroke.
These two questions have two very different answers.
If you're using two stroke oil as 4-stroke motor oil - get it out of there ASAP and do a short OCI to rinse all of it out.
If you're burning pre-mix in a 4-stroke, don't worry about it too much in small engine outdoor power equipment. Don't let the concentration get TOO high if you're talking about a catalytic converter equipped road vehicle.
Craig.
#894305 - 05/06/07 11:17 PM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: Craig in Canada]
Bill Kapaun Offline
Loc: Oregon
If the engine wasn't ran too long, it's probably OK.
Overfilled might have been a blessing in disguise, IF it didn't blow a seal.
I'd just refill with the proper oil and hope.
#894306 - 05/07/07 12:51 AM Re: If 2-Stroke Oil Is Used in a 4-Stroke Engine.. [Re: Bill Kapaun]
yeehaw1960 Offline
Loc: Nebraska
Chances are, if the engine didn't slowly sieze up you're fine. You may have shaved a year or two off the overall life of the mower, but these days, you can make a cheap one last for 10+ years or more.
