45500 Members
64 Forums
193743 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#881590 - 04/15/07 09:04 PM
Substitute for John Deere Hy-Gard J20D?
Loc: Illinois
I'm getting tired of paying John Deere's prices for their Low Viscosity Hy-Gard (aka Hy-Tran) fluid, otherwise known as "J20D".
Any one know of a substitute for this, from someone like Shell or Mystik?
Current inventory: 2 Honda 2 Ford 2 GM ...and a Chrysler.
#881591 - 04/15/07 11:37 PM
Re: Substitute for John Deere Hy-Gard J20D?
[Re: mrsilv04]
Loc: Forest On
What other suppliers do you use. Any of the major oil companies ( Shell, Exxon, etc) will have generic hydraulic/transmission fluids.
LIVE LONG & PROSPER.
#881592 - 04/16/07 02:40 AM
[Re: Don Stefanik]
Loc: East of IGO
Amsoil,Chevron,Shell,Scgaeffers,Valvoline.etc.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#881594 - 04/17/07 12:21 AM
[Re: salesrep]
Loc: Illinois
Just to clarify... All of these manufacturers/stores have the equivalent of *low-viscosity* Hy-Gard? I'm not referring to the regular stuff... If they all carry the equivalent of los-vis Hy-Gard, then what rock have I been under???
Edited by mrsilv04 (04/17/07 12:21 AM)
#881596 - 04/18/07 03:12 AM
[Re: mrsilv04]
Loc: Michigan
Citgo has Lo-Temp Trans Gard that meets the J20D spec.. Not sure if there is a Mystic(Citgo) equivalent.
Amsoil and Chevron have single products that meet BOTH the C and D rating. Top notch products, but initial cost probably won't be less.
#881597 - 05/01/07 06:35 AM
[Re: doitmyself]
Loc: PA
Texas Refinery Corp's Special Low Temp Universal Torque Fluid meets the JD J20D spec. It has a -50 deg pour point so low temp operation shouldn't be a problem.
#881598 - 09/18/07 01:17 AM
[Re: Wrehch]
Loc: Hawaii
Chevron "Synthetic All-Weather THF" meets JD J20C and J20D specs. Viscosity at 40*C/100*C is 44.7/9.5 cSt.
Chevron "THF W" meets J20D only. Viscosity at 40*C/100*C is 34.4/7.3 cSt.
10 Honda Insight PP 0W-20 06 Nissan Frontier ChevSupr 10W-30 87 Ferrari 328 ShellT6 5W-40 71 Alfa GTV ChevDelo 15W-40 64 Cobra ChevDelo 15W-40
#881599 - 10/21/07 11:38 PM
[Re: marco246]
Loc: Houston
Shell's product is Donax TDL.
#1024108 - 11/07/07 10:42 AM
[Re: mrsilv04]
Loc: Somerset County, PA
I'm getting tired of paying John Deere's prices for their Low Viscosity Hy-Gard How much are they charging for it mrsilv04? Reason I ask is a guy at the TractorByNet forum said he paid some amazing amount, like $10/qt or something, and I just got some from my local J-D guy on Saturday for $12/gal for my X595. It's definitely J20D "Low-Vis/HyGard".
"even if you're paranoid, they can still be following you"  "live so the preacher doesn't have to lie at your funeral"
#1118399 - 03/30/08 09:27 PM
[Re: RWEST]
Loc: Central Texas
Im curretly using Schaeffers Simplex in my 790. Works fine however not low vis. I did't I need low vis in Texas summer only use.
03 Golf TDI 10 Honda Civic 07 GMC 2500 6.0 gas
#1118453 - 03/30/08 11:10 PM
[Re: Neil Womack]
Loc: SW Ohio
I am using Amsoil Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30 (ATH) in my JD lawn tractor. It meets the specs for the J20D fluid.
#2161528 - 02/04/11 11:12 PM
[Re: mrsilv04]
Loc: NC
According to the Official John Deere service manual for Lawn Tractors LX255,LX266,LX277,LX2 (TM1754), You Can use a SAE 5W or 10W30 Oil (Synthetic or Mineral) or John Deere HY-GARD™ J20C Oil. Its your choice. I had some HY-GARD™ on the shelf in the garage that meets the J20D spec, but if I run out, its nice to know that I can use an SAE motor oil. I'd put a copy of the PDF on here if it was legal, but unfortunately I had to pay money to John Deere for it and I don't want to be sued for copyright stuff.
\/alvoline SynPower
#2169388 - 02/12/11 06:57 PM
[Re: mrsilv04]
Loc: kansastan
What's the application here?
For what it's worth, Deere does specify engine oil to be used as hydraulic fluid in quite a few applications- including machines that are far more expensive and powerful than lawn tractors. They'll often have a chart in the operator's manual showing a variety of engine oil viscosities and either standard or low-vis hyguard, depending on temperature range.
Case also uses engine oil in some of their skidsteer hydraulic systems. But they have an additional additive to put in with the 10w30.
The invisible and the imaginary look exactly the same.
