Are Cooper CS5 LRR?
by Stewart Fan
08/31/16 03:14 PM
Camry battery tested bad.
by chiefsfan1
08/31/16 03:08 PM
Electricly conductive grease for Samsung Galaxy???
by Drew99GT
08/31/16 01:40 PM
Right Oil and OCI for my Application?
by lancerplayer
08/31/16 01:06 PM
AZ card 20% off, AAP card 13% off
by gojoneeded
08/31/16 12:44 PM
NAPA (Flowers) Gold oil filter sale 9/5 to 9/10
by BigD1
08/31/16 12:38 PM
Japanese companies aren't as good !
by HTSS_TR
08/31/16 11:41 AM
Oil Viscosity Recomendation
by T_Bortz
08/31/16 11:35 AM
Clay, Polish, Wax OR Clay, Cleaner Wax
by SavagePatch
08/31/16 11:28 AM
VAICO Oil Filters
by tnt31
08/31/16 11:18 AM
Good oil and filter for hm 5.3
by Chevy538487
08/31/16 10:14 AM
At what timdo you consider your brake fluid "wet?"
by Bster13
08/31/16 09:34 AM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
93 registered (2015_PSD, 2009Edge, 2010Civic, 97f150, alarmguy, 09_GXP, 5 invisible), 1612 Guests and 11 Spiders online.
58973 Members
66 Forums
253815 Topics
#879152 - 04/12/07 11:51 AM Best way to clean/prevent gummed up small engines?
lars11 Offline
Loc: Sweden
Could happen to anyone. Small engines that are not being used for years may be interesting again. Like my 2.5hp outboard now that the kids want to play with small boats... It's an eraly 80s archimedes... Even older lawn mowers...
How do we clean them? Chemicals? If they start, i'd rather not take them apart but user some cleaner.
#879153 - 04/12/07 04:08 PM Re: Best way to clean/prevent gummed up small engines? [Re: lars11]
BUBBA0420 Offline
Loc: Cleveland Ohio
Run some Seafoam in the gas. Great for 2 strokes.
Those who dies with the most toys Wins
#879154 - 04/14/07 02:38 AM Re: Best way to clean/prevent gummed up small engi [Re: BUBBA0420]
wileyE Offline
Loc: Kitsap, WA
If it starts, idles, and runs at full throttle ok the carb is probably fine. The smallest orifice in the carb is usually the idle circuit so any gunking will show in poor or no idle.
If it's carbon on the piston, head, rings that your worried about you could use something like omc tune-up or similar product as directed (the stuff you spray in a running engine).
#879155 - 04/29/07 09:38 PM Re: Best way to clean/prevent gummed up small engi [Re: wileyE]
1 FMF Offline
Loc: CT
i have 2 big boats, holley 4b on one and a mercarb 2b on the other, have or have had numerous outboards all being 2-cycle, and have the usual: lawn mower, snowblower, weedwacker, and mantis tiller (2-cycle). rebuilt carb yesterday on the mantis that's been a real mf'er .
in all my experience, fwiw, additives in the gas are a complete waste of money. The only surefire solution is pull the carb apart, use carb cleaner and compressed air to clean it out, reassemble and use new gaskets if the old ones can't be salvaged.
the best preventative maintenance, these days with ethanol in the gas, is to make sure you get all the gas out of the carburetor before storage, especially outdoor storage. The ethanol will pull in moisture and water will develop in the carb bowl because it is vented. any other measures you can take are a good idea, such as storing equipment indoors or at least where humidity and temperatures don't change much. Basements are good, outdoor sheds not good.
gas stabilizer doesn't combat the real problem anymore, it's not the gas separating and going bad from storage, it's the water/moisture being pulled in because of the ethanol, and the water ends up forming rust and corrosion which leads to sediment in the carb.
#879156 - 05/02/07 05:33 AM Re: Best way to clean/prevent gummed up small engines? [Re: lars11]
Turk Offline
Loc: MN
Lars,
I would also take out the spark plugs & spray a little Fogging Oil into the cylinders. Then, pull the cord slowly several times and put new spark plugs in.
Good luck and let us know how you do!!!
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
