32956 Members
60 Forums
136839 Topics
Max Online: 941 @ 06/02/10 01:33 PM
#878653 - 04/11/07 09:09 PM
Question on 99 Taurus AT
Loc: SW Indiana
My brother's 99 Taurus had the 3.0L Vulcan and 4AT. Sometimes when taking off from a stop, it will feel like it didn't/won't shift down into 1st. It feels like it's trying to take off in OD. But it doesn't do this very often, only on occasion. The fluid hasn't been changed for a while, I'm sure.
Any thoughts and opinions? Thanks in advance.
2007 Honda Accord EX-L, 3.0L V6 (PP 5W-20) 2007 Ford Escape XLS, 2.3L I4 (MC 5W-20)
#878654 - 04/12/07 12:48 AM
Re: Question on 99 Taurus AT
[Re: LouDawg]
Loc: PA
No doubt that the first thing to do would be to change the fluid. Then take it from there.
#878655 - 04/12/07 01:06 AM
[Re: Vaca]
Loc: RI
Replace the vehicle speed sensor and the solenoid pack in the tranny.
If the VSS, solenoids, and new ATF/filter don't work, then you have bigger problems that can be fix/upgraded during the next rebuild.
Also, have the vehicle scanned for any errors and reset.
#878656 - 04/12/07 06:31 AM
[Re: unDummy]
Loc: Maryland
All those things are worth a try but also keep in mind that the AX4N transaxle is problematic and prone to sudden failure (I know that from personal experience with a 1995 Taurus). Losing first gear may be a sign of an impending failure of the tranny.
#878657 - 04/12/07 06:44 AM
[Re: RedDart]
Loc: North Arkansas
If this is only occasionally as you stated, I'd follow unDummy's reccomendations ASAP.
Bob
To which version of reality would you like to convert me?
Bob
#878658 - 04/12/07 06:46 AM
[Re: unDummy]
Loc: snowblind in TX
Well, before your brother throws any parts at it, pull codes first. He might get lucky and have a code to provide a starting point for a proper diagnosis. It doesn't sound like a major problem yet so there is time to spend figuring out the problem.
I don't see a VSS causing this concern, at least not without a few other symptoms being present.
Is the trans an AX4S or AX4N?
#878659 - 04/12/07 07:03 AM
[Re: punisher]
Loc: SW Indiana
Not sure whether it's the 4S or 4N...I'll check. But he did tell me this afternoon that it ALSO sometimes will not want to shift *out* of 1st and up into the higher gears when taking off. So looks like it's having occasional sticking or delayed shift on both ends.
#878660 - 04/12/07 07:05 AM
[Re: unDummy]
Loc: SW Indiana
Is this the same speed sensor that is suspected in causing his speedometer to drop to zero while driving, even though the car is cruising along with no problems? If so, could the issues be related?
Yes, I've been telling him to go have the codes pulled, but he hasn't made it there yet. I told him AZ will do it for free.
