Like the subject says, the 2006 upwards Honda Civic has an ATF fluid life monitor. Cool, eh.
Quote:
So, what does the transmission fluid life monitor manifest itself as in the new Civic? Is it an idiot light on the dashboard that glows amber with the words "TRANNY SURPRISE!"?
Quote:
I too just bought a 99 accord ulev/vtec 2.3L w/auto tans, and joined on here to discuss this same problem (good timing!) the AT problem was pinpointed to two things
Via H-T.com
a. Differential bearing failure- usually indicated by the axle seals leaking. the reason is Differental bearings were made from substandard parts
b. 2nd gear clutch pack failure- usually indicated by lack of second gear, excessive slipping in other gears, car redlines before shifting, delayed shifting (car hold current gear way longer than it should the reason is gear clutch pack does not receive proper lubrication
The recall was for 2000/01 6th generations.
So being without a warrenty, I want to change the ATF(auto trans fluid? don't know the "lingo" yet) as soon as I can, would over filling it a bit help the second gear at all? Is there a post regarding what fluid to use and how to flush the tans?
thanks. i know i am a noob, but please help.
