45904 Members
64 Forums
195354 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#866704 - 03/26/07 10:13 PM
Weed Eater edger
Loc: Cleveland, OH
I have a small 2 cycle edger, by Weed Eater. I believe it's 22 cc. I bought it a few years ago, and it handles my edging needs. I have a small yard and only edge a couple times a year.
There is one peculiarity though. It runs best only after 10 minutes of running or so. I start it per the manual, and it starts quickly. But until it warms up, I can't pull the throttle much, if at all. If I pull the throttle much it actually slows down, looses power, and stalls.
The hotter it gets, the more gas I can give it. But even if its been running a while and is very nice and hot, too much gas causes it to slow down and loose power and if I don't let go of the gas it will stall.
Should I adjust it somehow? If so - what do I do? Or do I just take it easy as it warms, like I've been doing.
(I've read some opinions on these saying they're garbage. I unfortunately didn't wisely research this purchase.)
Brian D. 2005 Pontiac GTO, 6.0L LS2, T-56 6-speed 2007 Buick Rendezvous CXL, 3.5L LX9, 4T65E
#866705 - 03/26/07 11:46 PM
Re: Weed Eater edger
[Re: bxd20]
Loc: Calgary Canada
You may need to leave the choke 1/2 on for a little longer.
If it loses power when you are opening the throttle (when cold) this is usually a symptom of the engine leaning out.
My 2 stroke homelite weedeater needs to run for a little while (maybe 2 minutes) on half choke until it warms up, then I can switch it over to no choke and it will make more power with no choke after that.
Until it's warm, mine does the same as yours if there's no choke. What doesn't add up is that it takes 10 minutes to warm up.
I also had a similar problem one year with my homelite, and it turned out to be an issue with my 2 stroke oil which was around 6 years old. I bought some fresh 2 stroke oil and some fresh gas, mixed it up and all my problems were solved. You might try that as well.
Jim A 07.5 GMC Sierra 2500HD LMM Rotella 15w-40 09 Odyssey EX-L CT 5w-20 66 Bronco QS 10w-30 08 BMW K1200S Rt 15w-40 08 Pitster Pro X4 Rt 15w-40
#866706 - 03/27/07 06:27 PM
[Re: Jim 5]
Loc: Cleveland, OH
Thanks for the tips. I had, for whatever reason, though it was going too rich when I pull the throttle. But obviously that is allowing more air into the carb and leaning it. I have generally not been using the 1/2 choke setting. I probably have been over-using the 2 stroke oil a bit as well. Will adjust both bad habits.  Thanks again!
#866707 - 03/27/07 06:46 PM
[Re: bxd20]
Loc: OKC
I just gave my Brother-In-Law my old working Weedeater brand string trimer and blower.The string trimer was between 15 to 20 years old. The blower was around 13 years old.
I purchased an acreage and needed a backpack blower and a multiple head trimmer.
#866709 - 03/27/07 10:15 PM
[Re: Jim 5]
Loc: Oregon
You might also check any carb mounting bolts for tightness. Even a SLIGHT air leak will have a large effect. Most power equipment is set on the lean side because of emissions.
#866711 - 03/29/07 09:09 PM
[Re: Sparkman]
Loc: Lynden, Washington
I wonder if perhaps I'm running too much mix oil in my little Echo trimmer 'cause it suffers from the same malady. Sure ran good when I put several ounces of toluene in the tank- no doubt it diluted the oil/fuel mix down quite a bit.
Then again, toluene has an octane rating ((R+M)/2) of somewhere around 114. Could that have helped it too? NAH...
The lean air/fuel mix symptom due to excessive mix oil is good to know because it seems counterintuitive.
Yes, Virginia, there is a Humptulips, Washington.
#866712 - 04/02/07 12:16 AM
[Re: Sparkman]
Loc: Cleveland, OH
I used the edger for the first time Saturday. Unfortunately less oil in the mix didn't seem to help. I ended up leaving it at 1/2 choke the WHOLE time, it gave me better power. In fact, near the end of the job I edged a patch on No Choke and it was worse than using 1/2 choke. By that point the edger would have been in use about a 1/2 hour. So I am definitely leaning out right? Would I find these "mixture screws" on the outside? I see one screw right off the bat, near the priming bulb. How much would I probably want to turn the screw to richen the mix, and in which direction? Thanks guys - I know my cars but small engines are still a mystery for the most part.  Brian
#866716 - 04/17/07 11:41 AM
[Re: Sparkman]
Loc: Washington
only used twice a year can lead to fuel gumming of piston, rings and cyl. always dump out fuel at end of each use, burn in mower or car fresh fuel each session use only a full synthetic 2 cyle air cool rated oil, far less gumming and deposits
clean the engine with a 50/50 mix of FP and LC into spark plug hole and let set for a couple hours with piston at top drain all out of plug hole and start, run under no load until hot at full rpm 5>10 minutes
