Oil for 1997 4runner with 300K
by claluja
02/09/16 12:54 PM
2003-2009 Lexus GX 470 Rear shocks for sale
by exman123
02/09/16 12:09 PM
Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
AutoZone Game...cash and gift cards
by eddielasvegas
02/09/16 11:51 AM
Dual platinum and iridium sparkplugs vs. standard
by DrRoughneck
02/09/16 11:31 AM
Kendall Super-Dxa 15W-40 SynBlend
by 2015_PSD
02/09/16 10:05 AM
2015 Ford F-250 6.7L MC Filter (9,800 miles)
by 2015_PSD
02/09/16 10:01 AM
Royal Shrovetide Football
by Whitewolf
02/09/16 10:01 AM
Intro and seeking used oil drums for small shop
by CRXPilot
02/09/16 09:47 AM
5000 mile OCI on dino?
by Whipped500
02/09/16 08:57 AM
API SG,SJ and SL Zddp levels
by FordCapriDriver
02/09/16 08:49 AM
GearWrench 3680D serpentine belt tool - $24
by pjhalifax
02/09/16 08:25 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
102 registered (1foxracing, 01_celica_gt, 901Memphis, 05Blazer, 97K15004WD, A1O, 9 invisible), 1699 Guests and 191 Spiders online.
56865 Members
66 Forums
244448 Topics
#813571 - 01/18/07 10:09 PM Ford F350 Tire Pressure
Ugly3 Offline
Loc: Chicago
My Grandson has a 2000 F350 and I drove it the other day. It was "all over the road" and hard to keep in the correct lane. I read the door sticker and it said 50 PSI in front and 80 PSI in the rears.
We put 45 PSI in both the front and rear (all the guage would read) and the handling got about 70 percent better.
What is the correct tire pressure for normal driving, no hauling, no trailer towing, no nothing.
I am guessing maybe 50 PSI front and 55 PSI rear.
No oil is thin enough at cold startup.
#813572 - 01/19/07 01:01 AM Re: Ford F350 Tire Pressure [Re: Ugly3]
JustinH Offline
Loc: Texas
The factory tire pressure ratings are probably to optimize rolling resistance, and thus fuel economy.
Also you will get better tire wear with more pressure.
If you are driving in winter conditions, a lower tire pressure would make sense, and would be safer if handling slick conditions.
'10 Toyota Rav4 Sport
'08 Toyota Matrix
#813573 - 01/19/07 01:05 AM Re: Ford F350 Tire Pressure [Re: JustinH]
eljefino Offline
Loc: ME
There have in the past been threads here where an empty truck was allowed lower PSI than one fully loaded, especially with LT tires.
Ford is unlikely to touch that one after the Firestone fiasco though.
#813574 - 01/19/07 03:20 AM Re: Ford F350 Tire Pressure [Re: eljefino]
alreadygone Offline
Loc: North Arkansas
What engine? Two or four wheel drive? The diesel trucks need much higher frt. pressure just to keep that beast supported.
bob
To which version of reality would you like to convert me?
Bob
#813575 - 01/19/07 06:03 AM Re: Ford F350 Tire Pressure [Re: alreadygone]
Ugly3 Offline
Loc: Chicago
Well, it is an F350 Diesel 7.3 liter 4 wheel drive.
#813576 - 01/19/07 09:05 AM Re: Ford F350 Tire Pressure [Re: Ugly3]
RH+G Offline
Loc: NY
I would run 50 in the front and about 60-65 in the rear if you are NOT pulling, towing.
#813577 - 01/19/07 09:27 AM Re: Ford F350 Tire Pressure [Re: RH+G]
Ugly3 Offline
Loc: Chicago
Just rolling along about 65 MPH or so.
#813578 - 01/20/07 02:10 AM Re: Ford F350 Tire Pressure [Re: Ugly3]
ewetho Offline
Loc: Kankakee, IL
Tire pressure is set to allow the full use of the truck as well. So with tire pressures on the placard you can go full load.
So do not expect to put a full load in the bed and tow something.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#813579 - 01/20/07 03:08 AM Re: Ford F350 Tire Pressure [Re: ewetho]
alreadygone Offline
Loc: North Arkansas
Don't think 50's enough with diesel 4X4 in front. Best bet would be to play with presures till you get ride, handling you want. Personally would care less what specs call for, long as tires stand up and ride,handle are ok.
Bob
Bob
#813580 - 01/20/07 09:47 PM Re: Ford F350 Tire Pressure [Re: alreadygone]
Bill_P Offline
Loc: Yorktown, VA
I Have a 2000 F-350 Crew Cab 2WD Diesel. My unloaded pressures are 62 psi front/52 psi rear with stock size tires (265-75-16). It rides pretty good and the tires wear nice and even. When I'm towing I'll put the fronts to 65 psi and the rears to 70 psi.
#813581 - 01/21/07 06:12 AM Re: Ford F350 Tire Pressure [Re: Bill_P]
Ramblin Fever Offline
Loc: Timberline
I know it's not the same truck, but we have the Dodge diesel cummins 4x4 quad-cab, door specs 65 frnt/80 rear
I run 60 frnt/75 rear unloaded without issue.
#813582 - 01/21/07 08:45 PM Re: Ford F350 Tire Pressure [Re: Ramblin Fever]
EK Offline
Loc: Pacific Northwet
Goodyear has a Service Load and Inflation Table for Light Truck tires...
http://www.goodyear.com/truck/pdf/databook/loadInflation.pdf
As a reference on my 2001 F-250 Crew Cab, V-10 I run studded Cooper Discover M&S LT265/75R-16 tires. I run 42 psi front and 30 psi rear when I commute with no load in the truck. These pressures provide a nice ride, reasonably uniform tread wear with exceptional snow/ice traction.
If I add more load, I increase the pressure appropriately.
#813583 - 01/26/07 07:15 PM Re: Ford F350 Tire Pressure [Re: EK]
williar Offline
Loc: Eastern Idaho, south of West Y...
When empty, the front tires should always have more air in them than the rear tires, since that's where most of the weight is. Have him take it to a public scale and weigh each axle. The 50 F / 80 R is for a fully loaded vehicle, not an empty one. With Load Range "E" tires (80 psi max), and a diesel, you'd want to run, say, 60F/45R.
And, your grandson should buy a good truck air gauge.
#813584 - 01/27/07 05:05 PM Re: Ford F350 Tire Pressure [Re: williar]
CapriRacer Offline
Loc: Somewhere in the US
I would be very careful reversing the pressure split. Low pressures in the rear tend to make the vehicle oversteer, and that makes it more prone to spin out. BTW, as a part of the development of the vehicle, they are driven on a handling course both empty and fully loaded at the pressures listed on the placard. So at the very least, the vehicle won't do anything terribly weird at those pressures.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#813585 - 01/30/07 08:57 PM Re: Ford F350 Tire Pressure [Re: CapriRacer]
occupant Offline
Loc: Columbus, OH
My '84 Suburban recommends 44psi front at ALL times. 51psi rear for "ride and comfort" and 80psi rear for maximum load (I have an 8600lb GVWR. 5200lb truck, 250lb me, 15-20 gallons of fuel, and a ton and a half of cargo and I'm at max.
Alan Moore - Columbus, OH
00 Suburban 5.3L 240K
