Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
05/24/16 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
05/24/16 05:49 PM
Tire Suggestions - 2014 Dodge Grand Caravan
by Nick1994
05/24/16 05:38 PM
Completing your 80% lower receiver manually
by Merkava_4
05/24/16 05:18 PM
5.4 3V VCT solenoid replacement
by 04SE
05/24/16 05:11 PM
Changed the spark plugs on Sunday, and [censored]??
by SirTanon
05/24/16 04:46 PM
Fram Ultra XG10060 Cutaway...
by AnthemBassMan
05/24/16 04:11 PM
The Vole (MS) now deceiving users to install W10
by simple_gifts
05/24/16 04:04 PM
5w20 + seafoam + hot weather + towing = ?
by meborder
05/24/16 03:15 PM
Chewbacca Mom & James Corden
by CharlieBauer
05/24/16 02:45 PM
This Radiator Looks Good to Me!
by Miller88
05/24/16 02:38 PM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
95 registered (albertdi, Barwich, 04SE, AnthemBassMan, Atesz792, aquariuscsm, 8 invisible), 1790 Guests and 113 Spiders online.
57966 Members
66 Forums
249359 Topics
Page 2 of 4 < 1 2 3 4 >
#813416 - 01/18/07 06:00 PM Re: Does oil freeze????? [Re: daman]
Volvohead Offline
Loc: SE Pa
Absolutely it does. But you have to get to temperatures so low that the only place they're commonly found is in a lab.
As has been said, most everything will turn to a solid below a specific temperature.
Some lubricants will also "dry out" or suffer component evaporation, depending on the atmospheric conditions (or lack thereof). I'm talking extremes here, and not just a dry Arizona day.
Ever wonder what NASA uses to lube moving parts on their interplanetary satellites? It's hundreds of degrees below zero out there (like -400F). I'd suspect dry lubricants and fully self-lubricating components and designs.
#813417 - 01/18/07 06:03 PM Re: Does oil freeze????? [Re: JAG]
daman Offline
Loc: Bad Axe, MI
Quote:
Not in normal winter temps. Freezing would mean you could turn it upside down and it wouldn't flow given any amount of time.
Thank you jag!!!! thats what i'm talking about normal
winter temps..
"Always"....Mobil 1
Current fill: AFE 0w30
#813418 - 01/18/07 06:06 PM Re: Does oil freeze????? [Re: daman]
daman Offline
Loc: Bad Axe, MI
i do realize yea every thing will freeze at a certain point,
i juess i should have stated that in my opening post.
"Always"....Mobil 1
#813419 - 01/18/07 06:14 PM Re: Does oil freeze????? [Re: daman]
lobo11 Offline
Loc: Midland, MI
I have some experience with hydraulic lubes and I have done a lot of pour point testing, in my experience in most cases I have seen oil is what I would call frozen 3-4 degrees C below its pour point, and will crystazlize there as well if it has any waxes. By frozen I mean in the testing apparatus the thermometer immersed in the oil is tough to pull out, and when it does it leaves a divot in the oil with oil from the divot stuck to the thermometer. SO if your oil lists a PP of -40 I would say based on my experience it would be what I call frozen at -45 to -42C. One true way to tell would be to run a DSC/DMS from -100 to 25 or so and get the glass transition temperature. But yes it freezes closer to the PP than most realize.
#813420 - 01/18/07 06:14 PM Re: Does oil freeze????? [Re: daman]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Yes, you should have stated an actual temperature range. Also, "normal winter temps" vary widely throughout the globe.
What is the word "juess"?
#813421 - 01/18/07 06:22 PM Re: Does oil freeze????? [Re: Pablo]
daman Offline
Loc: Bad Axe, MI
You don't know MR. spell check????
"Always"....Mobil 1
#813422 - 01/18/07 07:51 PM Re: Does oil freeze????? [Re: lobo11]
nascarnation Offline
Loc: Indiana
you're right on the money here
that's why the Army uses 0W20 instead of the usual 15W40 for their -60F arctic development testing
#813423 - 01/18/07 08:14 PM Re: Does oil freeze????? [Re: nascarnation]
Curious Kid Offline
Loc: Vermont
Sorry, but "normal", is there really such a thing? How about "average"? Even so...I digress.
The only constant is change.
#813424 - 01/18/07 08:25 PM Re: Does oil freeze????? [Re: Curious Kid]
Jett Rink Offline
Loc: Bristol, Tennessee
I was watching the history channel a while back, and it was a program about combat on the Russian Front. In the winter of 1941, it got so cold (we're talking 40 below zero, I think), that the Germans could not start the engines in their tanks. Engine frozen up, literally. They had footage of German panzer troops starting small fires on the ground under the tank to thaw out the oil so they could get them started. So yeah, it can freeze in severe winter conditions. I would have been curious to know what kind of oil the Germans were using then. The Russians didn't seem to be suffering this kind of problem. Perhaps the Russians, more used to dealing with lubricating engines in such severe conditons had some different oils?
2004 BMW 325i, 66,000 miles. 7 qts. of Mobil 1 0w-40 inside.
#813425 - 01/18/07 08:25 PM Re: Does oil freeze????? [Re: Curious Kid]
oilyriser Offline
Loc: Ontario, Canada
Paraffin wax has a viscosity of around 5-7 cSt at 100C, and freezes at maybe 60C, so in theory you could formulate a motor oil out of it that would freeze solid after the engine cooled off.
#813426 - 01/18/07 08:41 PM Re: Does oil freeze????? [Re: Pablo]
Bamaro Offline
Loc: Balto.
As defined by Fahrenheit hundreds of years ago, "normal" temperatures run between 0F & 100F. Therefore oil does not freeze at "normal" temperatures.
2015 Elantra
2009 Cobalt totaled by inattentive driver
1970 Camaro
2016 Civic
2015 Rogue
2014 Mazda3
#813427 - 01/18/07 08:55 PM Re: Does oil freeze????? [Re: Pablo]
bruce381 Offline
Loc: Millbrae, CA
it thickens to thwe point of being more like a havy grease or even like taffy candy.
bruce
#813428 - 01/18/07 08:58 PM Re: Does oil freeze????? [Re: Jett Rink]
wavinwayne Offline
Loc: North Alabama
I think I saw the same program. IIRC, the Germans began using synthetic oil at some point during the war, since it would flow much better in sub-zero temps. Someone please correct me if I'm all wet on that.
Silence is golden, but duct tape is silver.
#813429 - 01/18/07 09:02 PM Re: Does oil freeze????? [Re: Jett Rink]
TallPaul Offline
Loc: By Detroit
I doubt the oil in those tanks was frozen in a technical sense, just pretty thick.
Somewhere I heard that glass is not really frozen, but actually suffers creep, or at least glass in olden days, and that after many years it would be thicker at the bottom than at the top of a window.
I'm glad rocks have a very high freezing temperature. Steel too for that matter.
Often people on this site say they don't want their oil stash to freeze, meaning to experience temperatures at or below the freezing point of water, not that they actually think the oil would freeze.
Anyway, those are my thoughts, for what they are worth--and it's probably not worth much.
#813430 - 01/18/07 09:24 PM Re: Does oil freeze????? [Re: Pablo]
mechtech2 Offline
Loc: Chicago Area
Most oil is very good now, but some viscosities and brands will get very thick when it's really cold out. It doesn't 'freeze' in the strict sense of the word, but won't perform right as it congeals, and can most certainly cause engine damage.
