With a 0w-30 oil, I assume that the 30 is the actual weight of the oil but at freezing temps it will act as a zero weight oil. So, does this oil become thinner at colder temps? As the temps become higher through driving and during the summer months, then this same oil's viscosity would raise to at least the 30w or higher depending on the oil used. Correct? For instance the GC 0w-30 oil will actually become almost a 40w oil according to tests but at freezing temps it acts as a 0w oil? Viscosity numbers are confusing to me!
