Plug for Honda Mowers Pre-gapped?
by gofast182
05/21/13 09:33 AM
How clogged is clogged.
by GreeCguy
05/21/13 08:04 AM
Shoplifting, way out of hand here
by CourierDriver
05/21/13 07:18 AM
Honda HR214 Transmission
by firefighter11
05/21/13 07:01 AM
J B WELD
by browning300wsm
05/21/13 06:00 AM
5W-40 - semi or full synthetic....
by Shannow
05/21/13 05:37 AM
friction stir welding
by SteveSRT8
05/21/13 05:14 AM
Fuchs GT1 XTL 0W20 - 1,674km- 2010 Honda CR-V 2.4L
by IPCOlsenVZ
05/21/13 04:36 AM
Manual Transmission Rebuild - Grease New Bearings?
by E365
05/21/13 12:04 AM
Peak Global Lifetime $5.50 Pep Boys - Texas and ?
by Art_Vandelay
05/20/13 11:38 PM
2004 Volvo s80 Mobil 1 EP 9500 miles
by Kevinfc
05/20/13 11:31 PM
Bosch QuietCast brake pads...anyone use em?
by Stanley Rockafeller
05/20/13 10:42 PM
Kevinfc, toolhead, tempsho, JD2, oledad86
45483 Registered Users
124 registered (147_Grain, 2009Edge, 99Saturn, 05LGTLtd, AmishFury, 2010_FX4, 6 invisible), 1533 Guests and 242 Spiders online.
45483 Members
64 Forums
193706 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#812066 - 01/16/07 05:24 PM What makes Pentosin CHF 11S better?
brianl703 Offline
Loc: Manassas, VA
I can't find much information about this stuff. All I know is that it costs about $15 a quart, has a wierd fruity-type smell, and that most European vehicles specify it.
What makes it better than ATF or regular GM power steering fluid?
#812067 - 01/16/07 08:20 PM Re: What makes Pentosin CHF 11S better? [Re: brianl703]
unDummy Offline
Loc: RI
Extremely high VI of 320, thin CST, and supposedly very selective synthetic basesocks and additives make it special.
#812068 - 01/16/07 10:49 PM Re: What makes Pentosin CHF 11S better? [Re: unDummy]
Gary Allan Offline
Loc: Pottstown, PA
It's only matched by aviation grade hydraulic fluid. If you tried to buy that stuff, it would probably cost as much or more
This is the kinda stuff that makes you want to ring the neck of the guy who must have poured over spec sheets until he found the most obscure fluid he could come up with before designing a system around it.
I guess it could actually make the system simpler ...in that fluid viscosity would remain in a narrower range over broad temp spans ..but I imagine that this can only be a factor until the fluid reaches some operational temp . What are the negative side effects of not having that broad VI? What difference does it make if you never go outside a certain temp range? Someone's -25 is another's -5 ..is another's +20 is another's + 45. Every one of those people will experience the same visc at different times of operation ..and vastly different viscs at some point in operation ..regardless of if the fluid had a 320 VI or 599 VI or a 155VI.
http://lube-direct.com/gallan/
#812069 - 01/17/07 03:44 AM Re: What makes Pentosin CHF 11S better? [Re: Gary Allan]
brianl703 Offline
Loc: Manassas, VA
My Saab specifies it but the manual states that regular GM power steering fluid can be used for top-up. I don't believe the system requires the usage of CHF 11S, but that is what the factory fill is.
Could fluid life have been a reason for using it? Rack and pump life? Prevention of "morning sickness" 15 years down the road?
I am of course making the assumption that the power steering system is not specifically designed for CHF 11S, but the manual's suggestion to use regular GM power steering fluid for top-up backs that assumption up.
#812070 - 01/17/07 03:54 AM Re: What makes Pentosin CHF 11S better? [Re: Gary Allan]
brianl703 Offline
Loc: Manassas, VA
$20/gallon here:
http://www.skygeek.com/aefl411gabo.html
#812071 - 01/17/07 06:15 AM Re: What makes Pentosin CHF 11S better? [Re: brianl703]
unDummy Offline
Loc: RI
Its really simple. In certain cold climates, PS systems don't work too well. The high VI allows those northern euro vehicles to have a 'working' PS system in the coldest weather. Others up north will also benefit, eh?
I can noticed the difference between M1 ATF and normal mineral Dexron-III in my PS system and its only 16 degrees F outside now. Thanks to global warming and the big ozone hole, this has so far been a mild winter.
Less pump stress, less rack stress, less HP/MPG wasted,... are some side benefits.
The higher end synthetic can also be labelled 'lifetime' by the marketing departments.
Don't forget that some PS systems run overly hot. The super duper fluid can tolerate that heat without performance degradation and without shortening the life of the entire system.
I don't see the PS system designed around that fluid. I see the fluid as a bandaid for the weaknesses in the system. Weakness are now more evident then ever before in many automotive systems.
#812072 - 01/17/07 06:37 AM Re: What makes Pentosin CHF 11S better? [Re: brianl703]
moribundman Offline
1 liter costs $28 locally. I don't think I'll ever use it up.
#812073 - 01/17/07 06:41 AM Re: What makes Pentosin CHF 11S better? [Re: unDummy]
moribundman Offline
It's not like Pentosin 11s is a new type fluid. It's been around since, uhm, I can't remember, but it's been over 12 years.
#812074 - 01/24/07 09:11 AM Re: What makes Pentosin CHF 11S better? [Re: moribundman]
Auto-Union Offline
Loc: NEPA
Some intelligent thoughts on the subject here.
http://forums.audiworld.com/v8/threads/19625.phtml#109492
#812075 - 01/24/07 02:58 PM Re: What makes Pentosin CHF 11S better? [Re: brianl703]
Trav Offline
Loc: MA, Mittelfranken.de
Its just not for power steering systems,it is used in many Euro cars for hydraulic suspension and brakes,Audi,RR,Jaguars and a few others are using the Citroen system,the PS,brake booster,the main braking system fluid and suspension all use the same pump and fluid.These cars are identified by the green cap on the fluid reservoir.Not all models use this system or even all components of the system but it makes sense to me that they would use the same rack and pump in all vehicles. The Citroen type rack is unique in the sense it is self centering,not all users of the design utilize this feature.Newer versions of this system are speed controlled to divert pressure from the PS to the braking system at higher speeds.This is definitely not a poor design or lower quality unit using the fluid as a band aid.Castrol CHF can be subsituted for the Pentosin.
ASE L1, Master. Deutsch Meisterbrief
#812076 - 01/24/07 03:08 PM Re: What makes Pentosin CHF 11S better? [Re: Trav]
moribundman Offline
Citroen use Castrol LHM+ in their central hydraulic system.
Castrol CHF is interchangeable with Pentosin CHF 11s and is used in VW, Audi, Seat and Skoda power steering, convertible hydraulic systems, hydraulic transmissions, Daimler Chrysler power steering and ABC suspension, BMW leveling systems and central hydraulic systems, Opel electro-hydraulic power steering, Ford Galaxy power steering, Porsche convertible hydraulic, Porsche Boxter steering, Rolls Royce and Bentley power steering and hydraulic systems of the Silver Seraph and Arnage, and Saab and Volvo power steering.
Yeah, it's super-duper-ultra rare.
Edited by moribundman (01/24/07 03:10 PM)
#812077 - 01/24/07 04:43 PM Re: What makes Pentosin CHF 11S better? [Re: moribundman]
GMorg Offline
Loc: Mizzou-land
Are Pentosin CHF 11s and Pentosin CHF 202 interchangable for power steering applications?
Product page link:
http://www.pentosin.de/shop.php?c=214,228
#812078 - 01/24/07 09:07 PM Re: What makes Pentosin CHF 11S better? [Re: moribundman]
Gary Allan Offline
Loc: Pottstown, PA
WM? PB? AAp? AZ?
#812079 - 01/25/07 07:55 PM Re: What makes Pentosin CHF 11S better? [Re: GMorg]
moribundman Offline
Product page link:
Neither the product description nor the respective PDF data sheets say anything about compatibility or interchangeability between those two products. CHF 11s is a full synthetic fluid, CHF 202 is a semi-synthetic fluid.
Looking at the specs, CHF 202 is thicker when cold and has a higher pour point than the what appears to be superior CHF 11s. Both fluids meet the same quality level (ISO 7308).
The CHF 11s data sheet does not list Audi, which is strange, since my Audi requires that fluid. The CHF 202 data sheet lists VW.
CHF 202 must be a fairly new fluid, and based on the data sheets, I would expect CHF 11s and CHF 202 to be compatible. I would suggest that somebody take a look at a bottle of CHF 202. If it's compatible with CHF 11s it should say it right on it. But what about seal compatibility?
Edited by moribundman (01/25/07 08:06 PM)
#812080 - 01/27/07 08:53 AM Re: What makes Pentosin CHF 11S better? [Re: moribundman]
Da Game Offline
Loc: Chicago
I've heard that Pentosin may not be compatible with some of the metals in PS systems. Can someone comment on this?
