new HDM part number for lacrosse headlamp recall
by lucerne06
17 minutes 6 seconds ago
snapper blade control is stiff
by edwardh1
20 minutes 52 seconds ago
is my extension cord bad?
by motor_oil_madman
32 minutes 10 seconds ago
Done with Sandisk USB Sticks
by JHZR2
44 minutes 47 seconds ago
Pineapple Margaritas
by sleddriver
53 minutes 1 second ago
Replacing Drywall In The Bathroom (Insulation)
by Warstud
Today at 07:56 PM
351W build with a flat tappet
by ssregal39
Today at 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
Today at 07:12 PM
Car's models of 1990 and now
by HTSS_TR
Today at 07:02 PM
Another dealer oil change story
by mclasser
Today at 06:36 PM
Diagnosing HEI ignition module and ignition system
by Fsharp
Today at 05:58 PM
Spark such way?
by yvon_la
Today at 05:48 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
93 registered (4WD, bdcardinal, AZjeff, 69GTX, 74DartSport, 04SE, 7 invisible), 1582 Guests and 140 Spiders online.
58023 Members
66 Forums
249614 Topics
#811419 - 01/16/07 12:40 AM How much ZDDP in new 15-40 Delo LE?
RubbinIsRacin Offline
Loc: Central Texas
I've looked and looked on the forums for this and haven't found it. I thought somebody else might have asked so if it's already been posted somewhere just point me to the thread.
Thanks
#811420 - 01/16/07 01:12 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: RubbinIsRacin]
toocrazy2yoo Offline
Loc: Herndon, Virginia
Is the new Delo rated SM? I saw some SM HDEO of some sort the other day that was API SM. If so, it's light on the ZDDP, under 800PPM? Someone correct me if I'm wrong. That ZDDP content standard may also be GF4.
#811421 - 01/16/07 06:54 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: toocrazy2yoo]
427Z06 Offline
Loc: Austin, TX
YOU'RE WRONG. The SM rating in other than the GF-4 grades has NO phosphorous limits, thus NO ZDDP limit.
Delo 15w40 LE will have about 1200ppm of ZDDP.
http://www.chevron.com/products/prodserv/nafl/auto/docs/Chev_CJ4_faq.pdf
"What do you get when you multiply six by nine? - In base 13."
#811422 - 01/16/07 10:49 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: 427Z06]
edhackett Offline
Loc: Sequim, WA
Chevron Delo 400 LE SAE 15W-40 meets: API Service Categories CJ-4, CI-4 PLUS, CI-4, CH-4, CF, SM, SL ACEA European Service Categories E-7
TYPICAL TEST DATA
SAE Grade 15W-40
Product Number 222220
MSDS Number 17108
API Gravity 29.1
Viscosity, Kinematic cSt at 40C 125, cSt at 100C 15.7
Cold Crank, C/Poise -20/64
Viscosity Index 131
Flash Point, C(F) 204(399)
Pour Point, C(F) -30(-22)
Sulfated Ash, wt % 1.0
Base Number, ASTM D 2896 9.6
Sulfur, wt % 0.32
Phosphorus, wt % 0.12
Zinc, wt % 0.13
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#811423 - 01/16/07 06:38 PM Re: How much ZDDP in new 15-40 Delo LE? [Re: edhackett]
Loc: Central Texas
Thanks for posting that; it's basically what I was looking for.
427/Z06: Thanks for the link.
#811424 - 01/17/07 01:32 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: 427Z06]
Quote:
Ok, ok, I'm wrong! I said I might be..
But, at least it inspired the aquisition of the CORRECT answer..
#811425 - 01/17/07 01:54 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: toocrazy2yoo]
buster Offline
Loc: NJ
Quote:
Question:
What is API CJ-4 and what is different about it?
Answer:
The EPA has mandated changes for 2007 diesel engines and API CJ-4 is the corresponding diesel oil specification. CJ-4 is [an improvement over the previous CI-4 Plus API specification, although chemical limitations have been put in place for CJ-4. The reason for these chemical limitations has to do with the fact that 2007 diesel engines have a new device on the exhaust system. This new device is called a diesel particulate filter (DPF) which is designed to greatly reduce particulate emissions of diesel engines. Sulfated ash, phosphorus, and sulfur additives have been limited
Quote:
Why is DEO more expensive than other AMSOIL diesel oils?
Answer:
It is more expensive because the new additives used to replace zinc and phosphorus cost more. Additionally, supplemental dispersants and anti-oxidants are included to meet the API CJ-4 criteria.
Just the low sulfated ash formulation will contain lower ZDDP but for this oil your fine.
#811426 - 01/17/07 02:41 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: toocrazy2yoo]
427Z06 Offline
Loc: Austin, TX
I'm just disappointed I didn't teach you better.
#811427 - 01/17/07 02:51 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: buster]
427Z06 Offline
Loc: Austin, TX
Fine for what? And 15w-40 Delo LE IS the low ash formulation.
BFD on the ZDDP reduction, %0.148 versus %0.13, considering the other improvements made.
#811428 - 01/17/07 06:59 AM Re: How much ZDDP in new 15-40 Delo LE? [Re: 427Z06]
What you all taught me was I don't KNOW every fergin thang on this stuff. I thought I was a pretty knock-around guy on the subject having maintained most of my cars over 250K, dancing on the flight decks in support of NAVAIR for six and a half years and a lifetime of tinkering with everything from old mowers when I was 8 to airplanes on up to the stuff I do now, but the chemistry and philosophy behind it all, the educated parts, I never really considered much til I found BITOG. Like most folks here, I know a little something of many things, but not EVERYTHING about any one thing.
Hence, the qualification that ZDDP-content of 800PPM might just be ILSAC. If you asked most folks right here, point blank, the GF4 limit to zinc, and why there IS a limit, without looking it up, they'd go, HUH? I must have read here for maybe a year and a half before I ever registered and posted my first STOOPID comment. I qualify everything, and invite correction to anything.
Kinda scary some of the noobs lately, 427, the stuff they out with, and they have never read a word of the wisdom contained within these here pages before they start in on the old heads. Next thing you know, they're contradicting countless folks like Terry Dyson and his posts, MolaKule, the good Dr. Hass, RayH, EK, and yes, 427, even YOU, the learned folks that have FORGOTTEN more about this stuff than the rest will ever know, most of which they got from the aforementioned participants. I mean, how the hail do you argue the points of our Mr. Dyson with any authority? Yet you can find some ridiculous responses to his writings in this venue. And they don't dispute just Terry, either. Preposterous. Instead of picking the more knowledgeable folks' brains apart about this stuff, they argue GrandPa's viewpoints from 50 years ago, which were as wrong then as they are now.
There's always someone who knows more. THAT I was taught by my old man, a lesson sometimes (out of necessity) reinforced by a smack in the head..
