My 2 cents. I believe nitrogen has its' pros and cons. Water vapor in compressed air acts as a catalyst accelerating rust and corrosion (prevent wheel rim corrosion/rust and valve problems). Water vapor holds heat and when it changes from liquid to vapor, water expands alot in volume (consistent tire pressure, cooler running tires, and slows down tire wear). Since modecules of nitrogen are abit larger than O2, it will "leak" out more slowly through the rubber then O2. The only bad thing I see about nitrogen use is the non avaiability of it. It is unbelievable to see how many vehicles have "racing slicks", 10 PSI, 45-50 PSI overinflated, no or little brake pads, aligment problems, etc. which operate daily on the road and at highway speeds with us....(shudder!). I believe tire companies state more than 80% of vehicles run with under inflated tires, the use of nitrogen might be one small solution, but if you come right down to it....owner's failure to maintain their vehicle. Again just my opinion!
