Mixed oils
by measureman
05/19/13 01:01 PM
I need to work more weekends
by joaks
05/19/13 12:51 PM
Containers for hot oil
by EType
05/19/13 12:28 PM
Does TBN take an immediate hit?
by EType
05/19/13 12:21 PM
Amazon Mobil M1-601 filter $6 free ship
by 05GMC
05/19/13 12:21 PM
Washington Vacation
by panthermike
05/19/13 11:59 AM
Rust locked bolt/stud. Rust disolver
by landtoy80
05/19/13 11:37 AM
Rented a 2012 Camaro SS- Review+Trip pics
by panthermike
05/19/13 11:36 AM
Club meeting & pics
by widman
05/19/13 11:25 AM
Anyone tried Dr Beasley's Bug Barrier?
by 97tbird
05/19/13 11:24 AM
record keeping
by Fitter30
05/19/13 10:26 AM
Mid 90's Camrys vs Accords
by mjk
05/19/13 10:12 AM
mpalmer, Sami, jdaniel, lugNutz, Gage
45456 Registered Users
83 registered (77GrandPrix, 285south, 99Saturn, 05LGTLtd, Anduril, 97tbird, 3 invisible), 1742 Guests and 244 Spiders online.
45456 Members
64 Forums
193604 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#807606 - 01/10/07 07:05 PM '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. ?
Jim Spahr Offline
Loc: Lexington, SC
This 1997 2WD S-10 truck has an Izusu 2.2 L 4 cyl. with auto trans. It was a delivery truck for a parts supply co. It broke a timing chain while in service and the timing chain was replaced. It was missing on no. 3 cylinder. A compression check showed low compression on no. 3 cyl. Thinking the broken T. chain may have caused damage to a valve, they removed the cyl head and had a valve job done. Still 'missing' on no. 3. Now, if I am correct, a good valve job would include a new cyl. head gasket and R & R of all valves, then the ONLY remaining causes of a low compression on no. 3 cyl. would be a worn or bad set of rings on that cylinder. What else could cause a miss on no. 3? I am now including fuel problems and igniton problems as well as no compression. What are the common problems with the '97 Izusu 2.2L engine? Is this engine known to be a good engine or a problem one?
#807607 - 01/10/07 07:28 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: Jim Spahr]
Quest Offline
Loc: beaver land EH?
Are you still having low compression on #3 cyl?
If that is the case, make noises to the mech who did the head job for you to have it service properly. Chance are, he didn't do a good job in inspecting the damage.
I would not prematurely throw in all the "assumptions" and guesstimates in this case for there's no use crying foul when you broke the timing chain (and damaged the engine due to interference design)
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#807608 - 01/10/07 08:16 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: Quest]
Jim Spahr Offline
Loc: Lexington, SC
The 2.2 L Izusu engine is not an interference engine. However, I agree that you shouldn't believe all the mechanical tests and repairs were done correctly. Also your assumption that I 'broke the timing chain' is incorrect. This is a situation where an employee of a parts supply co. has bought the truck to fix up and sell. He still owns it and I am trying to find out what it will take to repair it.
#807609 - 01/11/07 04:23 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: Jim Spahr]
cousincletus Offline
Loc: Richmond, VA
If there is low compression on #3, then the best thing to do is replace the engine with one from the junkyard. This is the GM 2.2 OHV, which is known to be a good engine. The timing issue will make itself known before failure with a ticking sound. I believe the engine is the same as the 2.2 OHV Cavalier and a junkyard (www.car-part.com) will be able to tell you for sure. You should be able to find a low mileage engine cheap.
Fleet: 08 Chevy Colorado, 08 Malibu (wife's), 04 Impala.
#807610 - 01/11/07 11:29 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: cousincletus]
Jim Spahr Offline
Loc: Lexington, SC
I just went by the parts supply employee and spoke to him about this truck. He says it still skipped/missed after the new timing chain. It skipped after the new valve job. He thinks the problem is the mechanics who replaced the timing chain installed it wrong, amd it has 'jumped time' causing the miss. This is an Izusu 2.2L truck engine. There is a new Chevy Eco-Tech 2.2 engine for front wheel drive cars that you may be thinking of.
#807611 - 01/11/07 11:49 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: Jim Spahr]
johnd Offline
Loc: Austin, TX
If fought a miss for over a year until i finally traced it down to a missing platinum puck on the offending sparkplug. Sometimes the easiest things are the hardest to find. Also, I'm not buying "the timing chain causes the #3 cylinder to miss" either.
#807612 - 01/12/07 12:19 AM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. [Re: johnd]
Earl Filter Offline
Loc: Houston
I didn't see an answer to the question, "Is the compression still low on the #3 cylinder?" If so, there will be a completely different plan of attack vs. just having a miss on the #3 cylinder.
Brandon
2004 Dodge Durango 5.7
#807613 - 01/12/07 12:49 AM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. ? [Re: Jim Spahr]
JTK Offline
Loc: Buffalo, NY
If that 2.2L has a timing chain, I don't think it's an isuzu 4 banger. AFAIK, all the isuzu 4's had belts and were all severe valve smashers.
Joel
2012 Subaru Legacy 2.5i CVT, 2008 Honda Odyssey LX (Babe magnet II)
#807614 - 01/12/07 04:35 AM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. ? [Re: JTK]
Loc: Richmond, VA
Although I'm not completely sure, the Isuzu 2.2 is a GM OHV engine, the same that's in the S-10. Anyway, if there is low compression on #3 it's a boat anchor. Either rebuild or replace.
#807615 - 01/12/07 05:50 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. ? [Re: cousincletus]
Jim Spahr Offline
Loc: Lexington, SC
I am getting all this info second hand. I understand from the owner it is still missing on no. 3. I think it still has 'low compression' on no. 3 cyl. The present owner (seller) thinks this low compression is due to the miss alignment of the timing chain. I am assured the 2.2 Izusu engine does have a chain, not a belt.
#807616 - 01/12/07 06:41 PM Re: '97 S-10 w/2.2 L 4 cyl has miss on no. 3 cyl. ? [Re: Jim Spahr]
JTK Offline
Loc: Buffalo, NY
I had no idea this engine had anything to do with isuzu: http://cgi.ebay.com/ebaymotors/94-97-Che...069865411QQrdZ1
cam in block, hydraulic lifters, etc. I would think more than #3 would be messed with a sloppy chain, but I dunno much about this particular engine.
Joel
