2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
42 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 613 Guests and 204 Spiders online.
56834 Members
66 Forums
244295 Topics
#783832 - 12/07/06 06:45 AM SAE 10 & 20 Machine oils.
IFlyShamu Offline
Loc: Argyle, TX
I got a 1947 South Bend Lathe from my grand uncle and it states that the gear cases use SAE 10 and SAE 20 machine oil. I am having a hard time finding these oils on the internet. Have they been graded differently and what are the new grades and does anyone know where I can get a quart of each? I would like to replace the oils in the lathe for I suspest they still have the original oil in the gear cases.
Thank you, Don
#783833 - 12/07/06 07:53 AM Re: SAE 10 & 20 Machine oils. [Re: IFlyShamu]
1040 WreckerMan Offline
Loc: Western Washington
I've been using light gear oil in our lathes at work. I've also used EP hydraulic oils. Lathe gearboxes usually aren't terribly complex and they don't typically have heat problems, so really you just want some EP additives to help reduce wear and enough viscosity to protect against any shock loading (ya I know, there shouldn't be any shock loads here, but what should be and what happens are two different things).
HP = I'm spending money I don't have, on things I don't need to impress people I don't know!
#783834 - 12/07/06 10:12 PM Re: SAE 10 & 20 Machine oils. [Re: 1040 WreckerMan]
tom slick Offline
Loc: Central Coast, Calif.
The chart on this page should help
http://www.bobistheoilguy.com/visc.html
#783835 - 12/07/06 10:24 PM Re: SAE 10 & 20 Machine oils. [Re: tom slick]
wavinwayne Offline
Loc: North Alabama
McMaster-Carr sells SAE 10W & 20W20 oils. It might be worth checking their website.
Silence is golden, but duct tape is silver.
#783836 - 12/08/06 01:11 AM Re: SAE 10 & 20 Machine oils. [Re: wavinwayne]
IFlyShamu Offline
Loc: Argyle, TX
Thanks for the link Tom. The chart shows engine oil and I have been told not to use engine oil. I dont know why not but I was looking for machine oil equivelants. Are they the same?
Thanks for the info WreckerMan and Wavin. I will check them out.
#783837 - 12/08/06 03:27 AM Re: SAE 10 & 20 Machine oils. [Re: IFlyShamu]
TomJones76 Offline
Loc: Akron, OH
Don't know if the "machine oil" problem exists here, but Shell also makes 10 and 20 weight oils in Rotella.
#783838 - 12/08/06 07:17 AM Re: SAE 10 & 20 Machine oils. [Re: TomJones76]
The reason for the recommendation against engine oil is all about the additive package. All you need is a bit of EP and anti-oxidizer additives and not much else. You aren't dealing with a lot of moisture or combustion byproducts.
If you can't find any lightweight gear oil I'd just run something along the lines of an AWE15, 20, 25 hydraulic oil.
#783839 - 12/09/06 05:04 AM Re: SAE 10 & 20 Machine oils. [Re: 1040 WreckerMan]
Shannow Online   content
Loc: Oz
Prolly get away with ATF, or one of those 10W tractor oils (That's more of a maybe than the former).
#783840 - 12/11/06 08:49 AM Re: SAE 10 & 20 Machine oils. [Re: Shannow]
tom slick Offline
The proper way to read the chart is that SAE 10W roughly equivelent to ISO 22 to 32 and SAE 75W gear oil. SAE 20W is roughly equivelent to ISO 46 to 68 and SAE 75w to 85w.
confused yet? if we would only use the ISO system vis ratings would actually make sense.
my lathe at work calls for mobil vactra #2 in the gearbox and waylube. I have also had milling machines call out mobil DTE 797. both are proper viscosities for your requirement.
#783841 - 12/11/06 09:44 AM Re: SAE 10 & 20 Machine oils. [Re: tom slick]
bruce381 Offline
Loc: Millbrae, CA
just go buy a AW hydrualic oil
ISO 22 is a 10 wt
ISO 46 or 68 is a 20wt
basicily AW and Ocidation protection only.
ISO 22 will also work well in spindles.
bruce
#783842 - 12/28/06 03:21 AM Re: SAE 10 & 20 Machine oils. [Re: bruce381]
gigi riva Offline
Loc: the kettles
Grainger carries Mobil Velocite lathe spindle oils in both ISO 10 and 22 grades. I think MSC carries the Chevron line of synthetic ashless spindle oils.
Easy to find and cheap, I think Velocite goes for about 10 bucks a gallon, more or less
