Founder of BlackStone Labs passes away
by JetStar
02/09/16 06:10 PM
who uses a oil filter wrench?
by 15SilvyEcotec
02/09/16 05:56 PM
Heavy-duty combustion chamber cleaner
by TexasTea
02/09/16 05:23 PM
Motosel 5W30 Syn Blend / 15W40 HDEO VOA 1-28-16
by Farmer
02/09/16 04:47 PM
Mobil 1 oil filter quality
by dgunay
02/09/16 03:34 PM
help replacing door pins on a 98 corolla
by ziggy
02/09/16 03:26 PM
Bought an oil filter today.
by Taildragger
02/09/16 03:14 PM
15' Audi A4 quattro 2.0T Valvoline 0W40 7510 miles
by skyactiv
02/09/16 02:53 PM
Dodge Grand Caravan - Need Some Info
by Nick1994
02/09/16 02:47 PM
Oil for 1997 4runner with 300K
by claluja
02/09/16 12:54 PM
2003-2009 Lexus GX 470 Rear shocks for sale
by exman123
02/09/16 12:09 PM
Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
108 registered (15SilvyEcotec, ammolab, Al, 04SE, 901Memphis, 12 invisible), 1546 Guests and 211 Spiders online.
56865 Members
66 Forums
244457 Topics
Page 1 of 2 1 2 >
#780764 - 12/03/06 05:47 AM BG engine cleaner / engine purge
mckennaiii Offline
Loc: virginia
anyone used either of these products and what were your results?
BG Quick Clean for Engines
BG Quick Clean for Engines restores power and performance to your engine by rapidly and effectively removing accumulated deposits that form in the piston ring belt, hydraulic lifters, rocker arms and other critical engine parts. Add BG Quick Clean to the oil, then run engine for 10-15 minutes. When the old oil is drained, contaminants are quickly flushed away.
Part No. 105 11 oz. (325 mL) can
BG Engine Purge
BG Engine Purge is not an ordinary engine flush. It is an effective blend of solvents and dispersants which will quickly and safely remove accumulated sludge and other deposits from the engine. It can actually restore compression by removing soot and deposits from around the rings; hence, the compression rings seal in compression gasses. BG Engine Purge does not contain harmful chlorinated solvents. It may be used in conventional, diesel and rotary engines.
Part No. 120 32 oz. (946 mL) bottle
#780765 - 12/03/06 06:00 AM Re: BG engine cleaner / engine purge [Re: mckennaiii]
BrianWC Offline
Loc: Louisiana
Why do you need either, might I ask?
I'm sure they are okay but not worth the money. If you really want a flush, try something cheaper like b-12 or rislone....
But why do you need it? If you just wanna keep it clean for maitenance purposes, I can asure you arx or LC20 are better choices.
2002 Honda CR-V EX AWD
2014 Ford Mustang GT
2015 GMC Yukon XL SLT
#780766 - 12/03/06 06:05 AM Re: BG engine cleaner / engine purge [Re: BrianWC]
mckennaiii Offline
Loc: virginia
thankx.
just what i wanted to know.
#780767 - 12/03/06 07:05 AM Re: BG engine cleaner / engine purge [Re: mckennaiii]
ewetho Offline
Loc: Kankakee, IL
They are replacing the Part Number 105 with BG 109 which can be used in the same way or with the BG machine and it does seem to work. Had several cars running rough and cured the problem. Also in my Neon I had a typical Chrysler 4 cylinder (lifter tap bordering on knock at idle after warm) noise and now all is quiet.
It was either the Havoline 5W-30 solving what Mobil 7500, Mobil1, Royal Purple, Castrol Syntec, and Kendall GT-1 could not. Did it since new now it does not. Used to only happen in single digit weather and slowly got worse now it is gone.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#780768 - 12/03/06 05:48 PM Re: BG engine cleaner / engine purge [Re: ewetho]
TallPaul Offline
Loc: By Detroit
The engine purge sounds interesting. Might give it a try.
The masses, thirsting for convenience, unwittingly dig the grave of the automobile as we knew it. The industry already has one foot in that grave.
#780769 - 12/04/06 02:37 AM Re: BG engine cleaner / engine purge [Re: TallPaul]
Drew99GT Offline
Loc: Colorado Springs
Just finished a BG Quick Clean flush. Holy moly is that stuff strong! I took a wiff down the opened oil filler hole and just about fell over!
Oil drained like water and was absolutely black as tar with only about 2500 miles on it.
I'll report back in time with any results. I read a thread on the Saturn forums where someone used this product with great results in reducing oil consumption almost to nill. That's why I used it, to clean out the ring packs and get my 94 Corolla's oil consumption under control; recently it burned about a quart in only 800 miles.
#780770 - 12/04/06 04:01 AM Re: BG engine cleaner / engine purge [Re: ewetho]
psudaytona Offline
Loc: Pittsburgh,PA
Dang, sounds like mine. I have the 2.5L in my daytona. It has that "TAP-TAP-TAP" at idle to about 1700rpms as well. I hope LC20 can take it down a bit. Seems like its common in this particular motor.
1998 Crown Victoria Police Interceptor
4.6L V8
#780771 - 12/06/06 07:15 AM Re: BG engine cleaner / engine purge [Re: psudaytona]
ewetho Offline
Loc: Kankakee, IL
Yeah, we just decided to change over from MOC to BG (BIG IMPROVEMENT) and the new ahem Machine if you want to call it that just blows out the oil passages to get the BG109 and old oil out. Then re-primes the motor with their MOA and then you put new filter and oil in.
In every motor they demo (Normally a four cylinder for simplicity) it actually improves compression pressures. My car runs better. Mine was done sans machine but the clean phase is the same. Will just be short draining this interval to remove any residual 109. Wow good stuff.
#780772 - 12/07/06 05:35 AM Re: BG engine cleaner / engine purge [Re: ewetho]
Brett Miller Offline
Loc: Arizona
The tapping noise in your Daytona 2.5l is piston slap and wrist pins. Doesn't seem to hurt anything though as those engines run a long, long time.
#780773 - 12/07/06 06:50 AM Re: BG engine cleaner / engine purge [Re: Brett Miller]
psudaytona Offline
Loc: Pittsburgh,PA
Idk, I used a stethoscope and it seems to be coming from right on top of cylinder 1 right where the lifters would be. I listened on the head and block every few inches to trace the sound down. The area on top of cyls 2-4 are perfectly rythmic like they should be but above #1 there is a large amount of clatter and tapping. I figured either the lifter(s) for the cylinder were very dirty or on their way to a collapse.
I suspected piston slap and the infamous chrysler wristpin knock for a while but most tell me it should fade as the engine gets hot(cylinder expands) but it doesn't. It stays the same volume no matter what temp its at. Also, I cant hear any abnormal sounds on the engine block when I listen with the stethoscope. The sound is only audible on the steth whe its placed on the back/top/front of the valve cover above cylinder 1.
Gotta love these goofy little Chryco engines
4.6L V8
#780774 - 12/07/06 10:56 PM Re: BG engine cleaner / engine purge [Re: psudaytona]
Drew99GT Offline
Is the actual chemical formula between part numbers 105 and 109 different? All I know is that it was BG Quick Clean I used; had red labeling on the can. Oh, cost was only 7 bucks compared to the outrageous 25 bucks for 44K!! You can run 4 treatments of Redline SL-1 for that much.
#780775 - 12/17/06 06:30 AM Re: BG engine cleaner / engine purge [Re: Drew99GT]
Drew99GT Offline
bump.......anyone know? ewetho?
#780776 - 12/18/06 03:02 AM Re: BG engine cleaner / engine purge [Re: Drew99GT]
ewetho Offline
Loc: Kankakee, IL
Yeah, our BG guy said they reformulated 105 to 109. Now known as 109. 105 is apparently still around for some who just trust the good 'Ol stuff but 109 is the newest greatest stuff.
Old stuff know as BG Quick Clean with a part number of BG-105
New stuff simply known as BG-109.
As far as 44K being expensive it is and yes I am a serious an of Redline SL-1. Great stuff almost a miracle worker from some of the things I have seen and friends telling me how good it worked for them. BG is also pretty dang good.
Oh, my engine is still quiet after 2K+ even is the cold since the 109.
#780777 - 12/18/06 04:47 AM Re: BG engine cleaner / engine purge [Re: ewetho]
Drew99GT Offline
Thanks ewetho.
#780778 - 12/18/06 05:31 AM Re: BG engine cleaner / engine purge [Re: Drew99GT]
ewetho Offline
Loc: Kankakee, IL
No problem. If ya got any questions my BG rep is pretty cool. Not into chemistry but can get you all the releasable info you want on the BG stuff. So far most of it seems to work really well.
Just got to use the brake flush the other day and Wow what a difference just on a fluid exchange. Ain;t exactly cheap but they supposedly took like BMW's basic DOT4 formula and modified it some(they say enhanced). Got done with about an 01 crown vic and and the pedal was a ROCK!!!
Page 1 of 2 1 2 >
