Signature Limits?
by 2015_PSD
05/25/16 04:48 PM
pistol grip shotgun wanted
by FirstNissan
05/25/16 04:14 PM
microGreen Memorial Day Sale
by DBMaster
05/25/16 03:18 PM
Biomed Tech internship - Osceola, FL
by Mr Nice
05/25/16 03:06 PM
New Car - First OCI Subaru Outback
by Oldswagon
05/25/16 02:43 PM
using many cans of crc intake cleaner good?
by ziggy
05/25/16 02:37 PM
Mazda's RX Vision with rotary engine won't happen
by HTSS_TR
05/25/16 01:45 PM
Oil shearing vs fuel dilution
by Popsy
05/25/16 01:31 PM
Told SiriusXM to Pound Sand
by Garak
05/25/16 01:22 PM
CB install '98 F250ld
by asand1
05/25/16 12:53 PM
Kohler K532 Engine John Deere 400
by Bighorn2500
05/25/16 12:41 PM
Champion C165 cut open, 9000km
by turboseize
05/25/16 12:30 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
84 registered (AirgunSavant, AlaskaMike, asand1, 1JZ_E46, Atesz792, 11 invisible), 1816 Guests and 347 Spiders online.
57973 Members
66 Forums
249396 Topics
#777541 - 11/28/06 10:27 AM Motorcraft FL-300, FL-300W???
spunky Offline
Loc: Olympia, WA
I'm doing an oil change for a friend and would like to use a Motorcraft filter.
She has a '94 Dodge Spirit w/the 2.5L engine... The book at Walmart said to use "Motorcraft FL-300W", but the filter they had was "FL-300" (no W)... Even more odd, the tag on the shelf said FL-300W for the FL-300 filter (upc matched too). I matched it up with the other filters and it seemed like it would work, so I went ahead and purchased it. The other filters avail were Supertech ST16, and the Fram xx16 filters...
When I came home, I cross referenced the FL-300 and found Fram's xx16 filters listed also.
Is there really a FL-300W filter? or is this a typo? I didn't find any matches when searching on google.
#777542 - 11/28/06 11:31 AM Re: Motorcraft FL-300, FL-300W??? [Re: spunky]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
I use the FL-300 in my 2.5 Dodge. You can also use the long FL1A. Theres a Fram and Supertech that's longer. It the ST8... same number for the Fram.
#777543 - 11/28/06 11:58 AM Re: Motorcraft FL-300, FL-300W??? [Re: Triple_Se7en]
spunky Offline
Loc: Olympia, WA
I researched these filters more closely and found some interesting findings...
The Dodge 2.5L calls for the Wix 51085. My mom drives a 2000 Caravan w/the 3.0L V6 (Mitsu engine) that also calls for the same filter (would like to know if the FL-300 can be used on that engine too, 6g72)
Anyway, the Ford application of the FL-300 cross references to Wix 51068, where as Dodge calls for 51085. Both of these filters seem to cross reference to the Fram xx16 filters though.
Wix is nice enough to give their specs for the filters... The gasket size and thread are exactly the same for these two filters...
http://info.rockauto.com/WIX/DetailWIX.htm?www.wixfilters.com/filterlookup/PartDetail.asp?Part=51085
http://info.rockauto.com/WIX/DetailWIX.htm?www.wixfilters.com/filterlookup/PartDetail.asp?Part=51068
The differences I noticed where in the beta ratio (no idea what that means) and the burst pressure (275psi vs. 365; no idea what that means either)...
Since the 51085 has a higher burst pressure than the 68, does that mean the FL-300 could possibly fail when used on Dodge applications?
All this is so dang confusing, perhaps I should just install the silly filter and see what happens...
#777544 - 11/29/06 04:19 AM Re: Motorcraft FL-300, FL-300W??? [Re: spunky]
unDummy Offline
Loc: RI
Nope, your oil pump will fail if you had that much pressure in the filter!
Maybe that one filter has a thicker case then the other. That filter will tolerate more road debris. So, which application needs a wife(curb) proof filter?
Shorter filters also tend to have higher burst pressures even when the case is the same thickness. Take a look at the 51515 and 51773 burst specs.
#777545 - 11/29/06 10:00 AM Re: Motorcraft FL-300, FL-300W??? [Re: unDummy]
spunky Offline
Loc: Olympia, WA
Ok, I'm confident on using the FL-300 on the 2.5L Dodge.
Has anyone tried the FL-300 on Dodge Caravan's equipped with the 3.0L V6 (6g72 Mitsu)?
#777546 - 11/30/06 08:30 AM Re: Motorcraft FL-300, FL-300W??? [Re: spunky]
ewetho Offline
Loc: Kankakee, IL
I have been using it on my 2.0L Neon for a several oil changes now. FL-300W is probably a TYPO. 300 replaced the 200. That one may have been the lower burst pressure. Great filter low cost. Much
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#777547 - 11/30/06 11:11 AM Re: Motorcraft FL-300, FL-300W??? [Re: spunky]
Gary Allan Offline
Loc: Pottstown, PA
Sure ..that's what's supposed to be on it.
Essentially, spunky, the 3/4-16 filter with the 2.8/2.4 gasket is about the most widely offered filter on the planet. I mix and match up and down where I feel like it. My son's Neon takes the 3614 sized OEM ..it gets a FL300/PH16 sized filter. It can fit a FL1A sized ..but hangs below the pan. I put a heat exchanger on the wife's jeep. I can't fit a 16 ..so it gets a 3614 sized filter.
http://lube-direct.com/gallan/
#777548 - 12/10/06 03:38 AM Re: Motorcraft FL-300, FL-300W??? [Re: Gary Allan]
Buick92 Offline
Loc: Pullman Wa
I encountered the same issue at walmart, for my 2005 Grand Caravan it called for the FL-300W, I bought the FL-300 and figured I'd try it out, looks like a good filter for $3.28, is it a basic purolator or better? I know it dosen't have a silicone ADBV.
#777549 - 12/10/06 07:42 AM Re: Motorcraft FL-300, FL-300W??? [Re: Buick92]
Gary Allan Offline
Loc: Pottstown, PA
MC have shown very good results in particle counts. I have several in my filter shrine. That's right next to the oil vault.
#777550 - 12/10/06 06:54 PM Re: Motorcraft FL-300, FL-300W??? [Re: Gary Allan]
ewetho Offline
Loc: Kankakee, IL
At the dealership we list no FL-300W only Fl-300 from what I saw.
