Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
47 registered (09_GXP, 2015_PSD, AnthemBassMan, Al, 97f150, 5 invisible), 1053 Guests and 11 Spiders online.
58632 Members
66 Forums
252385 Topics
#750183 - 10/18/06 08:26 AM 2004 POLARIS JET SKI OIL
jayjay1 Offline
Loc: texas
I BOUGHT A 2004 POLARIS GENESIS JET SKI. THE OWNERS MANUAL SAYS TO USE POLARIS BIODEGRADABE NATURE OIL. CAN I USE ANOTHER TYPE OIL AND IF SO DOES IT NEED TO BE SYNTHETIC
#750184 - 10/18/06 05:06 PM Re: 2004 POLARIS JET SKI OIL [Re: jayjay1]
Mike_dup1 Offline
Loc: USA-Michigan
2 stroke or 4 stroke?
2012 Sierra Denali CC 6.2L AWD
2009 Cadillac CTS4
2010 John Deere X728SE
2006 Honda Rincon 680
#750185 - 10/18/06 06:05 PM Re: 2004 POLARIS JET SKI OIL [Re: Mike_dup1]
jayjay1 Offline
Loc: texas
it is a 135 hp and 2 stroke with automatic oil injection system
#750186 - 10/18/06 11:59 PM Re: 2004 POLARIS JET SKI OIL [Re: jayjay1]
Mike_dup1 Offline
Loc: USA-Michigan
Polaris likes to suggest their oils are better. A buddy has an 04 Polaris ATV and was buying it for a premium price and still had his engine go bad.
The wave runner is just like a snowmoble (big here) only for water. You could use anything that says its for injection but synthetic would be best in the long run. Better performance and cleaner burning engine. Amsoil HP Injector and Interceptor are very popular around here, but there are a ton of other oil to chose from, both cheap and expensive.
2009 Cadillac CTS4
#750187 - 10/19/06 12:07 AM Re: 2004 POLARIS JET SKI OIL [Re: Mike_dup1]
jayjay1 Offline
Loc: texas
thanks for the info
#750188 - 10/19/06 12:54 AM Re: 2004 POLARIS JET SKI OIL [Re: jayjay1]
JohnnyO Offline
Loc: Pittsburgh, PA
I have a 2000 Polaris. From the second year I had it I ran Polaris synthetic, it costs more but I save more than that in spark plugs. The Polaris dealer also sells Amsoil and told me that their Injector or Interceptor oils would be fine but I haven't tried them. This year I did run a gallon of Yamalube syn blend that my uncle gave me and had the same problem of fouling plugs very quickly that I did with conventional oil. I think any TC-W3 oil is fine but I'd stick with a premium synthetic because the plugs last a lot longer.
Steeler Nation does not have to travel. We're already there.
#750189 - 10/19/06 04:14 PM Re: 2004 POLARIS JET SKI OIL [Re: JohnnyO]
Brett Miller Offline
Loc: Arizona
I've had the same plugs in my 2001 Polaris for 2 years running Polaris Blue 2 cycle. I plan to stick with it.
#750190 - 10/19/06 05:48 PM Re: 2004 POLARIS JET SKI OIL [Re: Brett Miller]
TooSlick Offline
Loc: Dixie
it's marketing...all ester based two stroke oils are biodegradable to some degree.
TS
#750191 - 10/19/06 06:57 PM Re: 2004 POLARIS JET SKI OIL [Re: TooSlick]
JohnnyO Offline
Loc: Pittsburgh, PA
I think the "nature oil" is alledged to be more biodegradable so you don't get as much hassle from the greenies. There are lakes where two-stroke engines are no longer permitted. Most jetskis now are four-stroke, there are only a handful of oil burners now (and Polaris has quit making them altogether).
#750192 - 10/20/06 08:16 AM Re: 2004 POLARIS JET SKI OIL [Re: JohnnyO]
wileyE Offline
Loc: Kitsap, WA
I'd run the Polaris Blue before any tcw3 outboard oils. It's just blended more for motors like your ski than tcw stuff (metallic detegent pack). Most Polaris shops around here have a 55 gal drum and will refill your jug ($12-14 gal). Better oil may be out there but the blue has been around for years and proven to work as good as anything in polaris's entire product line. (the early blue WAS tcw3 and the had some problems with aircooled atv's, they quickly changed the formulation)
#750193 - 10/25/06 07:19 AM Re: 2004 POLARIS JET SKI OIL [Re: wileyE]
jetski_john Offline
Loc: St. Paul, MN
Oviously Polaris is going to recommend their own brand of oil because thats how they make their money. But in my opinion, Polaris Blue is some of the worst 2-stroke oil out there. Right next to Arctic Cat's oil. If you are willing to spend the money, Klotz is some of the best stuff out there and Amsoil is also right up there too but you're going to have to pay quite a but more for both over Polaris blue. I think Yamalube 2W is also a decent oil for a decent price and I run it quite a but also. Just make sure that when you switch oils, you try to run your oil tank down under a 1/4 before adding your new oil. Both oils should mix but it isn't the best thing to be mixing oils all the time.
#750194 - 05/14/07 11:19 PM Re: 2004 POLARIS JET SKI OIL [Re: jetski_john]
docvb Offline
Loc: Milwaukee
listen to the sea doo guys, and check the manual. Are the polaris oils TCW3 or do they require the low ash API-TC ratings? I recall the polaris oils are ashless, so any quality TCW3-rated oil will be your best bet.
I've tried the Amsoil Interceptor for my sea doos but all units developed leaks from the oil resevoirs--the engines are fine but now the $30./gal stuff leaks. RATS!!!
