Anybody use Shell Rotella T1 SAE 40 in boats?
by Bgallagher
4 minutes 31 seconds ago
"Scrub Radius"
by George Bynum
28 minutes 50 seconds ago
Any Subaru gurus here? EJ25 DOHC vague knock
by Why_Anything
33 minutes 22 seconds ago
Erdogan apologizes to Russia
by Jetronic
37 minutes 6 seconds ago
Terrible accident in So Cal last night.
by HTSS_TR
Today at 01:30 PM
Bought my first 0w-20 oil today
by shDK
Today at 01:22 PM
Tacoma Extended OCI
by 13Tacoma
Today at 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
Today at 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
Today at 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
Today at 11:16 AM
NJ's gas tax increase
by Whimsey
Today at 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
Today at 10:33 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
98 registered (4wheeldog, adamrc, ag_ghost, AandPDan, 10 invisible), 2108 Guests and 14 Spiders online.
58314 Members
66 Forums
250988 Topics
#748436 - 10/16/06 11:42 AM Non-conductive grease
nobobody Offline
Loc: Pittsburgh,Pa
I need a non-conductive grease that will not conduct electrical current 12 volt d.c For use in a neutral saftey switch on a car its a sealed unit with contacts and spring loaded brushes. that tell the transmission what gear is selected. the contacts were dirty i cleaned the whole unit. it had some grease in it but i flushed it out when cleaning. any ideas i dont want to short the unit out. beleve it or not this little switch is $300.00!!! so thats why im repairing it. thanks
#748437 - 10/16/06 06:36 PM Re: Non-conductive grease [Re: nobobody]
doitmyself Offline
Loc: MI
Sounds like you're looking for dielectric grease. You can buy small tubes at any auto parts store.
Here's a simple explanation from another site: "The primary purposes of dielectric grease is to keep out moisture, and
prevent corrosion. Prevention of corrosion keeps the metal-to-metal contact point in
a connector conducting electricity. If the grease conducted electricity, it
would allow the tracking to ground of the power or signal being conducted. It's
neutral and forms an excellent 02 block. Also lubricates but w/o any specific
bulk. Wont' work for heavy loaded bearings, etc. Great for multiple plug
blocks, relay contacts, slide contact switches, rubber lube, speedo cables when
combined w/graphite, etc. In addition it is used for a heat conductor when some
electronic components are mounted on surfaces to dissipate heat (like the
ignition power stage on coils). It is non-conductive, but when you slide the
connectors together there is metal-to-metal contact and the grease gets displaced
but the area around connector is protected from moisture"
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#748438 - 10/17/06 08:07 AM Re: Non-conductive grease [Re: doitmyself]
bruce381 Offline
Loc: Millbrae, CA
think they are gelled silicone oils try the stuff that goes on a spark plug boot so it will not stick to the plug.
bruce
#748439 - 10/17/06 08:52 PM Re: Non-conductive grease [Re: bruce381]
brianl703 Offline
Loc: Manassas, VA
Nyogel 760G. Sold by Ford dealers as terminal grease. It's a little thinner than what is usually sold as silicone dielectric grease. I have a tube of it and I can post the part number if you want.
Edited by brianl703 (10/17/06 08:53 PM)
#748440 - 03/22/07 08:59 PM Re: Non-conductive grease [Re: brianl703]
Master ACiD Offline
Loc: sebring, florida
amlost any lithium grease (even crisco for frying) ia non conductive.
"Kerosene that is fully additive formulated may make a good oil." -aehaas
#748441 - 03/23/07 06:45 PM Re: Non-conductive grease [Re: nobobody]
moribundman Offline
Plastilube is non-conductive.
